Old Boiler Maintainence? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-14-2009, 12:51 PM   #1
old boiler maintainence?
Do boiler heat systems need to have the water lines cleaned? Mine is a oil boiler with radiant baseboard heat and it just doesn't seem to heat very well.
ToddB is offline   Reply With Quote
Old 10-14-2009, 06:21 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Yes
The water in the pipes as well as the heat exchanger
The water in the piping needs to be tested to see if the Ph is good. To much acid can eat the pipe from the inside out
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-14-2009, 07:19 PM   #3
So boilers work on a closed loop system? I have lived in this place for 4 years and I know that the water has never been tested. I have baseboard radiators, and if I put my hand down in it the pipe that heats it is super hot but there is almost no heat coming off the actual radiator. Is there a better radiator that can be put in?
Old 10-14-2009, 07:20 PM   #4
They probably need to be bled
If they have air in them they will not heat up
Should be bleeders near the top
Old 10-14-2009, 07:32 PM   #5
Rewards Points: 560
Scuba-Dave has a good point too...May have air in the system
If I may if you are not used to working on boilers then PLEASE call a pro.
A boiler is just like a water heater and what I call a controlled time bomb. By all means don't take this wrong but this boiler can blow without notice from making changes to the system.
I would tell you to call a pro and ASK TONS of questions so you can understand and repair
Good luck
Old 10-14-2009, 07:35 PM   #6
Just asking on this one so I don't get the run around when I do call. Thanks for the concern
Old 10-14-2009, 07:53 PM   #7
Rewards Points: 560
That great I agree that you have knowledge so that you don't get screwed
If this boiler hasn't been serivced in awhile then you may have some scale build up on the heat exchanger and that can cause a heat transfer issue
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
pilot light on crown aruba boiler mazzonetv Plumbing 1 05-28-2009 10:13 AM
Tankless coil in oil-fired boiler lebeld Plumbing 4 01-18-2009 08:48 AM
Burnham V7 series oild-fired boiler is turning itself off Pickngrin HVAC 6 01-12-2009 08:26 PM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
