Old Boiler & Baseboard Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2010, 01:50 PM   #1
old boiler & baseboard removal
i recently got a new forced air furnace & havn't removed the old boiler & baseboard heating elements. i would really appreciate any suggestions on how to go about removing it myself. especially when it comes to the copper piping! it's very frustrating!
lmhunter1 is offline   Reply With Quote
Old 12-13-2010, 02:12 PM   #2
Licensed Master Plumber
Sawzall and a hammer
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
The Following User Says Thank You to NHMaster For This Useful Post:
LateralConcepts (12-13-2010)
Old 12-13-2010, 10:22 PM   #3
Rewards Points: 150
Complete steps I would follow
Drain it all the way
If you are good with a recip cut the pipes out... I would start at the top floor and go down so if you get any water in the system it will be minimum to clean up.
When you get to the Boiler... two ways to remove them
Your Muscle
Someone elses muscle
I prefer the second especially if it is an old cast iron... I have a guy that will come and remove them for free.
If I need to remove it and it is Cast Iron I break it down by removing the shell... Cutting the bolts... then use a hammer and chisel to split the seams. more work but it will save your back especially if you have steps. Steel you are stuck removing them in one piece. Either way spend a couple of dollars and buy some good plastic to cover the floor. The black crap can ruin EVERYTHING
Docwhitley is offline   Reply With Quote
Crown Boiler closed system baseboard heat chefscott67 HVAC 4 11-04-2010 08:43 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 06:03 PM
How do I bleed air from my baseboard heat / boiler rodney23 HVAC 5 10-01-2010 10:04 PM
Flooring and Baseboard Removal hammermonkey Flooring 3 01-10-2009 06:45 PM
convert from gas boiler to electric baseboard marks5894 HVAC 1 10-21-2007 12:22 PM
