Old 12-28-2012, 10:38 PM   #1
Ok to use p-trap with swivel/union fitting for bathtub?
I just ordered the bathtub for our basement reno and while at the local HD I saw a few different p-traps. The one in question here is a swivel style with a union joint, as pictured below. Is there any downside to using this style of trap over a completely solid/glued trap? I figured the union would allow more flexibility for installation.
hpsguy is offline   Reply With Quote
Old 12-28-2012, 11:21 PM   #2
if it will be accessable then yes, if its buried in the floor or in between floors then no.
The Following 2 Users Say Thank You to DannyT For This Useful Post:
hpsguy (12-29-2012), Javiles (12-29-2012)
Old 12-28-2012, 11:26 PM   #3
It will be used in the basement, so not really all that accessible once I install the tub and fill in around the trap with dirt.
Old 12-29-2012, 01:09 AM   #4
Master Plumber
Javiles's Avatar
As per Danny T no can not be used in application,you'll need a solvent weld trap.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
hpsguy (12-29-2012)
Old 12-29-2012, 02:56 PM   #5
Thanks folks. Off to get a silent week trap and some other goodies for the ongoing project.
PVC trap adapter on galvanized trap? dougan Plumbing 2 10-05-2012 07:16 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 08:59 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 08:02 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 06:30 PM
