OK I Have To Ask Copper Solder Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2013, 10:00 PM   #16
We flooded a basement on my first plumbing job. Everything held just fine. Came back the next morning to find out i was fired. The boss was holding a piece of 1/2 inch pipe with what he described as my finger print on the piece of pipe they had to cut out. I took the blame for that one because the other guy showed up earlier than me and said I was to blame. Another time I was fixing a leak that had frozen . I heated it up hit it with some flux sweat it. It did not draw right, I turned on the water and it held great. Came back home 4 hours later to a very fine mist in my bathroom. I had another one go but the lady pulled the strapping out with her hose on the riding lawn mover.
paintdrying is offline   Reply With Quote
Old 01-27-2013, 10:09 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 684
Ever see a sprinkler head blow and flood an office because one of your crew was brazing a med gas fitting in a confined area and the torch got too close to the head? Man that water in fire lines is dirty
Or how about a hydronic reheat coil leak over night in a hospital and ruin the PC at a doctor's desk?
Old 01-28-2013, 05:22 AM   #18
DIY staff
Rewards Points: 7,174
You guy are scaring me with these stories!!
Old 01-28-2013, 07:02 AM   #19
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Ok...so I'm not the only one.....
I think I'll crawl under the house to have a look at my plumbing now....
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (01-28-2013)
Old 01-28-2013, 08:40 AM   #20
Rewards Points: 3,130
I worked with a guy that was a perfectionist---we piped in 5 mixing tanks with pipes and valves--pumps--all 4" victalic--a run of over 40 feet---
We missed our mark by 3/8"---it drove him nut to think his math was off---6 months later we tore off the insulation so he could find the mistake---
I used to work as a maintenance foreman at a nuclear power plant. Talk about Quality Control! An error like your 3/8" would've been caught by the inspector at the end of the job and would've failed it.
Old 01-28-2013, 09:24 AM   #21
Plumber
Rewards Points: 684
It's to the point that if I hear a hissing sound like spraying water I break out in a cold sweat
Old 01-28-2013, 09:45 AM   #22
Roofmaster
Rewards Points: 2,210
Perfectionist, or Craftsman? I guess there is a thin line. One thing is for sure, The fix ages you a lot less than the nightmares that the mind can create.
The Following User Says Thank You to jagans For This Useful Post:
paintdrying (01-28-2013)
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Plumbing alignment issue (plastic to copper) muhren Plumbing 4 12-30-2010 08:20 PM
Soldering Copper chimney flashing buzzymalone Roofing/Siding 10 08-10-2009 08:28 AM
transition from copper without solder? djrussell Plumbing 16 07-09-2009 02:12 PM
copper vs pex mn49 Plumbing 11 04-26-2009 04:55 PM
