OK I Have To Ask Copper Solder Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-27-2013, 06:34 PM   #1
Rewards Points: 108
OK I have to ask Copper solder issue
I soldered a 3/4 piece of copper pipe to a dimpled coupler. Installed it and noticed that its not prefectly straight in the coupler, but it does not leak.
So my question is: Is this going to fail? and should it be addressed now?
Dont ask me how this happened, I dont know.
If I have to correct it, is there a shortcut to fix this?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 01-27-2013, 06:38 PM   #2
Rewards Points: 14,278
Got a picture?
Near impossible to get one on crooked unless it's not all the way on.
There a line to line fit.
oh'mike (01-27-2013)
Old 01-27-2013, 06:40 PM   #3
Rewards Points: 108
Will take one tomorrow.
Old 01-27-2013, 06:44 PM   #4
DIY staff
Rewards Points: 7,174
Crooked is not seen often---like Joe said---
Usually a joint can be heated----realigned--brushed with flux and soldered without disassembly or additional cleaning------usually----well,most times---
Old 01-27-2013, 06:49 PM   #5
Rewards Points: 108
Thanks, these couplings were the ones I got off of ebay. I did not remember that he sent me some normal ones and some with just dimples.
Was tired so I finished up and came home. Maybe we just did not straighten the 10 foot run out? Will double check it tomorrow and make a decision.
Regarding all of my solder joints, I see no leaks, but I guess time can bring those on?
Old 01-27-2013, 06:50 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 900
If the pipe is not supported near the joint, it will sag. The fitting can have excessive tolerances. As stated, if the joint was prepped and soldered correctly you should be OK-except that is crooked.
One of the most obvious places this occurs is the copper stub outs for tubs- no one likes a saggy spout
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 01-27-2013, 06:52 PM   #7
Rewards Points: 108
Saggy Spout, isnt that what Viagra is for? Oh wait, wrong forum!
Thanks!
Old 01-27-2013, 06:54 PM   #8
A "normal" one would have "dimples" a repair coupling would not.
digitalplumber (01-27-2013)
Old 01-27-2013, 06:56 PM   #9
Rewards Points: 108
OK never used one before so I assumned it would like the ends on a 90.
Old 01-27-2013, 07:13 PM   #10
I would just go ahead and replace it. If it is not seated properly then not all the surface area of the joint is properly joined. I have not see anything like that before. I would guess the tolerances are off.
paintdrying is offline   Reply With Quote
The Following User Says Thank You to paintdrying For This Useful Post:
Old 01-27-2013, 07:14 PM   #11
DIY staff
Usually---if they don't leak--then they are good for ever----
Old 01-27-2013, 07:22 PM   #12
Plumber
Rewards Points: 900
True, Not to put the OP down, but it's considered a sign of sloppy craftsmanship on the part of the plumber. It happens a lot when you don't pay attention to the pipe alignment. Just stand back and look at your work before you solder You can reheat heat it and apply a little side pressure till it cools
Old 01-27-2013, 07:27 PM   #13
Rewards Points: 108
No offense taken, if I were a pro then I would be worried. Need to look at up close and not down the line so to speak. It may just be a slight mis alignment in the pipe, not a crooked conect with the coupler.
Thanks for all of the help!
Old 01-27-2013, 08:17 PM   #14
Roofmaster
Rewards Points: 2,210
I would fix it. There is very little chance of misalignment in this case, and your joint is holding on by a thread. You know it, and so do we. Plus it will drive you nuts, knowing its like that.
The Following User Says Thank You to jagans For This Useful Post:
Old 01-27-2013, 08:27 PM   #15
DIY staff
I worked with a guy that was a perfectionist---we piped in 5 mixing tanks with pipes and valves--pumps--all 4" victalic--a run of over 40 feet---
We missed our mark by 3/8"---it drove him nut to think his math was off---6 months later we tore off the insulation so he could find the mistake---
Question about copper pipe agroom Plumbing 3 10-27-2011 02:18 PM
Plumbing alignment issue (plastic to copper) muhren Plumbing 4 12-30-2010 08:20 PM
Soldering Copper chimney flashing buzzymalone Roofing/Siding 10 08-10-2009 08:28 AM
transition from copper without solder? djrussell Plumbing 16 07-09-2009 02:12 PM
copper vs pex mn49 Plumbing 11 04-26-2009 04:55 PM
