OK To Drop The Trap Under A Shower? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-13-2011, 05:10 PM   #1
OK to drop the trap under a shower?
I want to get the drain under the 2x10 floor joists so the line draining away, runs below the joists and not through them. The ceiling below is dropped so this is not an issue.
Thus the drop down to the trap is a long one, about 10 inches.
Any problems doing it this way?
JohnstownFlood is offline   Reply With Quote
Old 03-13-2011, 05:15 PM   #2
No problem
SuperPlumberGuy is offline   Reply With Quote
Old 03-13-2011, 05:17 PM   #3
max tailpiece in my code is 24"... you'll be fine
the_man is offline   Reply With Quote
Old 03-13-2011, 06:10 PM   #4
Tank u veddy much. Much more comfy here on the DIY board, where pros like you guys don't mind giving a little advice to non-plumbers.
But let me ask further, 'cause now I see an opportunity in the crawlspace as well.
Would this "tailpiece" thing apply to a toilet, too? In other words, can we drop through the joist depth and head out drain perpendicular to and under the 2x10 joists? Am thinking of making the turn from plumb to horizontal with a long sweep 1/4 bend.
Old 03-13-2011, 06:22 PM   #5
technically its not a tailpiece for the toilet, its a trap arm but yes, it's actually ideal. not the best thing to drill or notch those joists
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 12:39 PM
shock in shower tbwoods Electrical 64 07-23-2009 11:26 AM
drop ceiling - shower will1 Painting 2 04-05-2009 06:47 PM
