-   -   OK Changed mind so which Pex brand (http://www.diychatroom.com/f7/ok-changed-mind-so-pex-brand-163339/)
digitalplumber 11-14-2012 04:16 PM
Which Pex Brand to use for re-plumb?
Where to buy?
Crimp, clasp or what?
Thanks!
tylernt 11-14-2012 05:57 PM
We bought Sharkbite brand PEX from HD because it was cheapest. The 1/2" and 1" was easy to deal with. The 3/4" was a pain to work with (real stiff) though.
We also went with copper crimp rings. No scientific reason, just didn't think the clamps would hold as well. And I for sure wouldn't use "push-fit" connections!
Got the Apollo crimp tool from Lowes. Used Lowes Apollo crimp rings and fittings too, just because they are closer to our house. Zero failed crimps, fortunately.
Daniel Holzman 11-14-2012 07:40 PM
This topic has been discussed ad nauseum on this forum, do a search for PEX or similar titles and you will find many threads. Opinions vary widely on the topic, personally I used Wirsbo tubing with Wirsbo fittings and was very happy with the results, but the tool is expensive. Read the threads, see what others think of crimp fittings and sharkbites.
TheEplumber 11-14-2012 07:56 PM
I'm a fan of wirsbo as well, I have used it on 1.25" and larger, Used all 3 methods on smaller pipe- own all the tools :laughing: I'll use which ever is the flavor of the day.
BTW- I tried searching "pex" on here- the word is too short and it upsets the search function.Try some of the brand names, etc.
digitalplumber 11-14-2012 08:25 PM
As much as you dislike folks that dont use the search, I dislike folks that make comments like this then go on to answer the OP.
