Oil Hot Water How To Disconnect - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-11-2014, 11:03 AM   #1
oil hot water how to disconnect
like to know how to shut off hot water from the oil furnace and hook up a elecetric hot water tank
caleb/cody is offline   Reply With Quote
Old 05-11-2014, 11:34 AM   #2
Little more info and a picture would help as well.
ahrens is offline   Reply With Quote
Old 05-11-2014, 01:57 PM   #3
Rob
Robpo's Avatar
Rewards Points: 826
Is the furnace Just for hot water?
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
caleb/cody (05-11-2014)
Old 05-11-2014, 02:29 PM   #4
no the furnace is for hot water and base board hot water for heat
Old 05-11-2014, 05:21 PM   #5
An old Tradesmen
Rewards Points: 7,270
Post pics of boiler piping so that we can see it to tell you how to pipe it.
Old 05-11-2014, 06:47 PM   #6
Rob
Robpo's Avatar
Rewards Points: 826
So is the new hot water heater just for domestic hot water or for heat also.
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-08-2014 11:40 PM
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
