Oil Heat Furnace Coil - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2009, 08:07 AM   #1
Question
oil heat furnace coil
just want to know how to install a oil heat furnace coil????????????
RAMAN62 is offline   Reply With Quote
Old 05-09-2009, 08:08 AM   #2
how to install a oil heat furnace coil? 2 years ago i had a problem with my furnace coil and it wasn't producing enough hot water so the heating company advised me that i have to install a electric water heater so it will work like a reservoir so i did...and everything was working fine for last two years and now recently i have a problem with the hot water pressure in the whole house. the hot water pressure is too low. is it possible to replace the heating coil to solve this problem or there is something else wrong???? i called the oil company who have the contract for the furnace for the tune up on the furnace and the guy who did the tuneup have no clue about this problem......so may i know what is wrong and how to fix it????
No heat from furnace. sofakingwyld HVAC 10 11-06-2010 07:24 AM
first time startup on Bryant furnace - furnace calls for heat and will not stop luvheat HVAC 22 02-14-2009 09:56 AM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
