Oil Furnace - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-03-2012, 12:54 PM   #1
oil furnace
furnace is for heat and hot water, can i make my hot water heat by electric?
edward2012 is offline   Reply With Quote
Old 10-03-2012, 01:36 PM   #2
Rewards Points: 152
As in an electric water heater? Yes, they do exist.
Old 10-03-2012, 02:29 PM   #3
Rewards Points: 3,130
With some minor plumbing changes, of course you can. Assuming you have enough electrical capacity.
Old 10-03-2012, 05:11 PM   #4
biggles's Avatar
40-50 gallon range is typical for a medium size family 230Vs is required check your circuit breaker panel for room
Old 10-03-2012, 07:04 PM   #5
Rewards Points: 1,216
Your best bet is a electric water heater, you have to disconnect the piping in and out of your boiler to the new electric water heater, you can install a piping arrangement to do this and still keep your boiler piping in place in case the electric water heater breaks and with the turn of a couple valves you can have a backup. You might have to make an adjustment to the aqua stat control on your boiler.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
inducer blower wont work on my heil gas furence dre123 HVAC 2 04-10-2011 12:49 PM
