-   -   oil furnace (http://www.diychatroom.com/f7/oil-furnace-158849/)
edward2012 10-03-2012 01:54 PM
oil furnace
furnace is for heat and hot water, can i make my hot water heat by electric?
DexterII 10-03-2012 02:36 PM
As in an electric water heater? Yes, they do exist.
md2lgyk 10-03-2012 03:29 PM
With some minor plumbing changes, of course you can. Assuming you have enough electrical capacity.
biggles 10-03-2012 06:11 PM
40-50 gallon range is typical for a medium size family 230Vs is required check your circuit breaker panel for room
COLDIRON 10-03-2012 08:04 PM
Your best bet is a electric water heater, you have to disconnect the piping in and out of your boiler to the new electric water heater, you can install a piping arrangement to do this and still keep your boiler piping in place in case the electric water heater breaks and with the turn of a couple valves you can have a backup. You might have to make an adjustment to the aqua stat control on your boiler.
