Oil Burner, No Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 10:30 PM   #1
oil burner, no hot water
I have a columbia em-110 oil burner, heats water for baseboard heater+household hot water. Burner seems to fire up and run normal. baseboard heat ok, but when turn on hot water faucets, I only get somewhat hot water for about 30 seconds, then barely tepid.
thebruce is offline   Reply With Quote
Old 01-29-2012, 07:49 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,626
Ayuh,.... Donno where you are, But,...
My boiler will do that, If the zones of the house are All callin' for Heat....
My guess is, the boiler just can't keep up, when Everything is callin' for heat, at the same time...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
plummen (01-29-2012)
Old 01-29-2012, 08:09 AM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
Thats easy to fix. Move to Florida.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 01-29-2012, 10:39 AM   #4
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
When was the last time you serviced the boiler?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
condensation dripping onto water heater burner SubSailor Plumbing 1 01-01-2011 10:02 PM
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-27-2010 11:00 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
