-   -   oh these faucet instructions! (http://www.diychatroom.com/f7/oh-these-faucet-instructions-151927/)
petros151 07-29-2012 06:13 PM
I have searched to find the answer to this question but cannot find it -- I have a new kitch faucet there is a shorter and longer water inlet copper pipe leading into the faucet housing --- nowhere does it say which is hot water -- I'm guessing the longer but why attach and then re-do if I'm wrong?
someone of you folks surely knows this easy answer....
instructions arghh !!! :furious:
ben's plumbing 07-29-2012 06:29 PM
hold faucet the way it is going to install on sink...make sure handle is in off position...turn it on to cold and blow through tube:thumbsup::thumbsup::thumbsup: should find cold side...:thumbsup::thumbsup:
petros151 07-29-2012 06:32 PM
thanks good idea BUT it's installed already and sink is in I figured the instruction would tell but no! so I don't think I can get to those pipes to blow into one....
gotta be a standard thing I would think for any manufacturer ... ??:huh:
ben's plumbing 07-29-2012 09:11 PM
there all different hook up the supply line to stub comming down from faucet ..then blow in that.....or just hook up short to hot long to cold and try it.....if wrong reverse it....done deal:thumbsup:
petros151 07-29-2012 09:20 PM
thanks-- went back to the original store they had a similar faucet same maker and that one had stickers on the hot cold pipes long is HOT -- Im' guessing this is standard way to distinguish on a single barrel faucet design....
:thumbsup:
Alan 07-29-2012 11:27 PM
I had a single valve once that I installed with that assumption, but there must have been something funky in the guts, because they were actually backwards.
No-name faucet however, so who knows what they were thinking.
Probably something along the lines of : $$$$$$$$
petros151 07-30-2012 09:01 AM
yes I was wondering that because after the pipes go into the barrel the could have twisted around- someone told me generally if you look at the faucet as it will be sitting then the left pipe would be hot in this case the pipes were front to back from each other when looking at the front of the faucet ... so maybe nothing is standard but it makes sense to put a sticker on there! this was a Hampton Bay from you know where
ben's plumbing 07-30-2012 11:20 AM
yep and that was your 1 st problem:laughing::laughing::laughing: glad you got it ....ben sr
