Oh, The Decisions For Shower, Hot Mop? Kerdi? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2012, 01:30 AM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 1,162
Oh, The Decisions for Shower, Hot Mop? Kerdi?
Just when I think I have it figured out....I read more here...and I don't have it figured out....
I will be ready to build my two showers soon....one is pretty standard....32"x60"....the other.....anything but standard.
Seeing how we want a tiled shower floor....a prefab pan is out of the question.
As I understand it....I have 3 options...Hot mop, Membrane, and Kerdi.
Until a couple of days ago...I was leaning towards Kerdi....until I had a chat with a friend who just had a shower hot moped.
A quick review of each system (mostly talking out loud)
Hot Mop - Do a built up motar bed first...then the hot mop guy comes in and puts down multiple layers tar paper and hot tar. A proven system with a long history
Membrane - Same basic initial steps as above except you use a rubber sheet.
Kerdi - Almost the same as hot mop....except you use the Kerdi material as your water proof layer.
Membrane is out...best I can tell is that it's an 'ok' method....but it looks like hot mop or Kerdi is better.
Kerdi looks to be more expensive for materials....but a lot less labor. Excluding the motar base that you have to do for both....with Kerdi, you don't have to do blocking between the space between lower studs. With Kerdi, you just run cement board or Hardibacker down the walls....and the Kerdi goes on top.
What is the best long term method?
We intend to be in this house for a long time....I don't want to go through what I did with my existing bathroom and it's cracked shower pan (hot mop)
ddawg16 is online now   Reply With Quote
Old 12-17-2012, 10:00 AM   #2
Rewards Points: 52
Never used them but there are ready made options:
http://showerbase.com/
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 12-17-2012, 10:15 AM   #3
JOATMON
ddawg16's Avatar
Yea....I looked at those. Most of the reviews I read were not very good.
And then I have that issue with the non-standard size shower.
Old 12-17-2012, 10:18 AM   #4
Rewards Points: 52
I would and we are, going to do Kerdi in my son's shower build.
Old 12-17-2012, 10:19 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What's wrong with the membrane? That's all people use around here unless it's DIY, then we see things like the kerdi system.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Ishmael (12-17-2012)
Old 12-17-2012, 10:33 AM   #6
Ditto.
It's quick, simple and relatively inexpensive.
And make sure - whatever you ultimately decide - that you wrap that bench seat (aka - "litigation seat") also!
Ishmael is offline   Reply With Quote
Trouble with Schluter Kerdi Showe System The_Nick Tiling, ceramics, marble 7 12-07-2010 09:17 PM
Bathroom floor - Kerdi Band for Ditra / drywall joint? Airgibson Flooring 12 08-04-2010 10:33 PM
kerdi fix drying under membrane hacksepe Building & Construction 1 09-30-2009 10:35 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
