-   -   Offset toilet flange installed correct? (http://www.diychatroom.com/f7/offset-toilet-flange-installed-correct-108951/)
acerunner 06-27-2011 01:16 PM
1 Attachment(s)
Is this offset toilet flange installed correctly?
My plumber screwed up the rough in of the toilet. So he put in a offset flange to fix the problem. I can see the top of the cast iron pipe and it is flush with the CBU and the bottom of the flange, creating a moon shape pocket. This to me seems like a terrible idea. A pocket where things will get caught and very easily clog the toilet.
acerunner 06-27-2011 11:43 PM
1 Attachment(s)
heres a better angle
Stephen S. 06-28-2011 12:53 AM
1 Attachment(s)
I'd say it's wrong ... it should be one straight/offset continuous pipe down the drain ... seems like there'll be always be standing water collected at the red arrow area ... or worse, leak out at the gaps between offset and iron pipe (blue arrows) ...
Homerepairguy 06-28-2011 02:11 PM
Originally Posted by acerunner (Post 675610)
Wow, I can't believe a licensed plumber would do that! :no:
bob22 06-28-2011 02:59 PM
Time to get a new plumber. I wouldn't let him/her fix this since they were clueless to begin with.
Bud Cline 06-28-2011 05:13 PM
That does NOT look like an "offset flange".
That looks like a flange that has been offset.:)
It would probably work but I agree you need a different more competent plumber.:)
Is this guy a comedian?:)
acerunner 06-28-2011 06:25 PM
really? It's not an offset flange? I just thought it was installed correctly, the cast iron pipe needs to be cut down lower. Look at where the bolt holes are.
Looks like this one. http://www.plumbingsupply.com/images...ue-c40-640.jpg
Although I can't see the compression gasket on the one i have installed.
Can you show me an example of the one that SHOULD be used? Many of the ones I search online are pvc/abs.
Bud Cline 06-28-2011 06:49 PM
Calm down calm down. I have never ever seen one of those things before and didn't realize it had all of that garbage below the ring. Looks kind of hoky in the first pictures.
Sorry, I WAS MISTAKEN, now go take a heart pill and don't beat up on your dog.:)
LateralConcepts 06-28-2011 06:52 PM
acerunner -
If the flange is identical to the one you've pictured above, it'll work but the cast iron needs to be cut down. It shouldn't be any higher than the top of the rubber compression ring.
TheEplumber 06-28-2011 07:06 PM
199 Attachment(s)
Use a small grinder and score about half way through the pipe at the elevation you want. Then use a cresent wrench or vice grips to grab the edge of the pipe. Apply outward pressure. It will snap along the score line. Problem solved :drink:
acerunner 06-28-2011 07:16 PM
you have misread the tone of my comment.
notice "really? It's not an offset flange?" instead of "really?!?! It's not an offset flange?!?! What are you, a moron?!?!" :jester: I was not trying to give you a hard time. You just gave me a moment of worry there, both in doubting my own ability to recognize plumbing components, and that my plumber is a bigger moron than I already think he is. Until I found the picture online of what looks to be the same part. So in your face! :laughing: *joking*
i agree, compression ring is inferior. I would have preferred a continuous pipe, but at this point, I don't know how you would be able to install it. This is over a sleeper floor above on-grade slab foundation, so there is no access below.
LateralConcepts 06-28-2011 07:29 PM
I agree with Eplumber. Try a Dremmel. Just gonna take some patience and a beer or two..
TheEplumber 06-28-2011 07:31 PM
199 Attachment(s)
acerunner, that is not an inferior flange IMO. Well, maybe any offset flange is inferior, but what other choice do you have given your floor system? The compression gasket is quite good. At least the ones I've installed.
acerunner 06-28-2011 07:46 PM
my thinking is that you always want to assemble pipes in such a way that in the direction of flow will not run into any edges, like for hubbed cast iron pipes, the hubbed side is always downstream of the flow.
So this compression flange breaks the rule.
Next best option would be continuous offset pipe with hubless connection. Or better yet, no additional bend at all. You are right though, given my circumstance, there is no other way unfortunately.
acerunner 06-28-2011 07:53 PM
oh and bud, i'm glad my post made your "keepers" list. :thumbsup:
