Offset Curb Sewer Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2013, 09:30 PM   #1
We have only recently started getting some water backed up into the basement shower (Iowest and closest point to the street). I used an auger from the toilet hole and cleared it.
Two weeks later the main sewer line clogged fully which backed up into the basement. Water and crap was overflowing into the basement.
The plumber came and snaked the line from the curb towards the street and it cleared quickly. He ran the camera and the line to the house and clear and in good shape.
He said that the 8 ft long vertical curb line/cleanout at the sidewalk is offset and that is the reason we got a clog. I looked down the hole with a flashlight and there is a slightly shifted middle section of pipe but it looks like that section is above where the waste comes from house and flows to the street.
My questions are:
1. Using the photo and description, what is your opinion of the problem? Is the plumbers assessment correct or was he trying to pull one over on me?
2. Does this sound like just a clog from using Charmin in a cast iron piping?
3. Based on what you think the problem/solution is, what is a good price for getting this fixed?
Thanks in advance Everyone!
psubaron is offline   Reply With Quote
Old 02-04-2013, 09:48 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by psubaron View Post
We have only recently started getting some water backed up into the basement shower. I used an auger from the toilet hole and cleared it. Two weeks later the main sewer line clogged fully which backed up into the basement. Water and crap was overflowing into the basement.
AKA the landlords baptism
What are you calling the curb?
Did he not snake the line from INSIDE the house out to the street?
How old is your house?
Have you asked your neighbors how many have had their lines replaced?
Old 02-04-2013, 09:54 PM   #3
Hey again Tarheel Terp. The plumber only snaked from the curb down about 10ft total from the surface. That cleared the drain and he then inserted the camera from the sidewalk and ran to the house.
Old 02-04-2013, 10:08 PM   #4
MarginallyQualified
The curbstone at the street where you park the car?
btw no one cares about vertical.... it's the horizontal that matters
(see pic at bottom)
Again...did he not snake the line from INSIDE the house horizontally through the whole pipe and out to the street?
Have you asked your neighbors if or how many have had their lines replaced?
Old 02-04-2013, 10:11 PM   #5
Apologies....not the curb. Its the vertical 8ft long pipe (the overflow/gas relief I think?) In the sidewalk.
No he went from the sidewalk vertical to the inside.
Old 02-04-2013, 10:38 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 826
The picture appears to only show the clean out riser- not the sewer line itself
Get more bids
Old 02-04-2013, 10:41 PM   #7
Yes I also just thought it was a vertical section of the cleanout which has nothing to do with the actual line going from the house to the connection to the street.
I do apologize for not knowing proper nomenclature for items described. I am learning for the first time.
Old 02-04-2013, 10:48 PM   #8
Plumber
Rewards Points: 826
Looked at the picture one more time- looks like a cast iron riser(appears to be thin walled pipe) but the fitting at the base looks like clay(thick wall at the offset) If it is truly clay you need to seriously start saving for a replacement. Clay is joined every 3 ft and tends to get a lot of roots. It also cracks and offsets with age
Old 02-04-2013, 10:57 PM   #9
I was told that the even the bottom section was an older thick cast iron and the riser was thin walled. Again, I am no expert so I am going off what others have told me.
So in your opinion the offset wouldn't cause the clog/backup? I bought this house almost two years ago with no problems til now. Before me, my wife's grandparents and Dad were living here for 40 years and they only had clogs and had someone come snake the drain twice in that time.
Old 02-04-2013, 11:14 PM   #10
MarginallyQualified
No need to apologize for not knowing stuff.
But we do sometimes have to "pull teeth" to get the pertinent info.
Some mistake that for being rude or mean... not the case.
The offset, the riser, the clean out and the vertical pipe you have
pretty pictures of is all ABOVE where the "clog" would be.
The concern is the nature of that "clog"
At 40 plus years... that old clay WILL fail.
It's about about if or could... it's *when*
Old 02-04-2013, 11:27 PM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 996
To answer your question which you keep asking and no one replies too the answer is no not from whats in that picture that would not cause a back up now you may have another offset he seen with the camera in the main or lateral?get a second opinion. i don't know about your area but down here most city public works departments will take care of anything past the second clean out, wait for a second back up use a different company and see what they tell you or get the city and see if they will camera it for free.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-04-2013, 11:45 PM   #12
Thanks for the answer. I believe he was making it up because he came to that conclusion as soon as he opened the cover and we shined a light down and saw just what I posted. There wasn't any clog or material visible. He then snaked several feet beyond the bottom of the vertical and found the clog which cleared the line. He then ran the camera from the sidewalk into the house and there were no trouble areas. So I couldn't gather how he determined that the vertical offset was the cause.
Trap on main sewer line? mazzonetv Plumbing 3 12-03-2012 03:20 PM
finding a sewer line av-geek Plumbing 16 01-19-2012 06:56 PM
Help!!! Roto-rooter cable is now stuck in sewer line and won't come out!!! YerDugliness Plumbing 21 01-28-2010 03:04 AM
Can a roof vent identify where my main sewer line exits the house? YerDugliness Plumbing 8 01-26-2010 04:13 PM
Main Sewer Line repair Unregistered Plumbing 3 03-14-2005 07:10 AM
