Offset Closet Flange - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2012, 06:24 PM   #1
Offset closet flange
Greetings,
I have a new toilet that touches the back of the wall and will not connect properly with the closet flange. I want to put in an offset closet flange. The only problem is that the flange sticks out of the floor about 2-3 inches. I know I will probably have to bust up some concrete. Will I have to cut the waste line as well in order to get the flange in correctly? Also the center of the waste line is less then 12" from the wall.
pjm30043 is offline   Reply With Quote
Old 05-22-2012, 06:47 PM   #2
DIY staff
Rewards Points: 7,174
SLOW DOWN--- What is the pipe made of?
Exactly how far from center of pipe to the wall?
Old 05-22-2012, 06:56 PM   #3
It is made of PVC. it is 11 inches from the center of the pipe to the wall.
Old 05-22-2012, 07:07 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 922
Use the existing flange, Buy a toilet for 10.5" rough in
Old 05-22-2012, 07:13 PM   #5
E-plumber I would but I already have the new toilet and I don't think it can be returned.
Old 05-22-2012, 07:20 PM   #6
Plumber
Rewards Points: 922
Weigh your options- bust up the floor, possibly move 90,etc.
Or sell an out-of-the-box toilet on craigs list
Old 05-22-2012, 07:24 PM   #7
Rewards Points: 582
check to see if the commode you purchased comes in 10"rough in ...if it does sometimes they only use a smaller tank????? just my 2 cents..ben....what make did you buy..
Old 05-22-2012, 07:25 PM   #8
DIY staff
If you want to keep that toilet--you will need to see what the 'throw' is with an off set flange--
If it is acceptable--start chiseling out the concrete around the pipe-
Cut the pipe and prime and solvent the new flange in place--repair the concrete and screw the flange to the floor--
Time consuming work,but fairly simple--an inside cutting tool for your drill might help to cit the pipe--
Old 05-22-2012, 07:29 PM   #9
Rewards Points: 636
buy a 10 inch rough in toilet. big box stores usually carry one toilet that is or better choice get one from plumbing store
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-22-2012, 07:30 PM   #10
It's an american standard saver cadet 3 with 1.28 gal a flush.
Old 05-22-2012, 07:30 PM   #11
Rewards Points: 582
I have never had much success with those offset flanges.....call after call for stopped up commodes......solution...remove offset flange ....problem solved...Iam just saying....
Old 05-22-2012, 07:34 PM   #12
I already bought the toilet and It was used for about a month before it started leaking. So It will be difficult to try and return it I think and I'll lose money on if I buy another toilet.
Old 05-22-2012, 07:46 PM   #13
Rewards Points: 636
sorry a little slow on post i see that it was already suggested. can you access from pipe from below and can you take a pic from above and maybe below if accessible
Old 05-22-2012, 07:48 PM   #14
It is coming out of a concrete slab. I can take a pic.
Old 05-22-2012, 08:00 PM   #15
Rewards Points: 636
man not fun. an offset is out unless you want to remove concrete. i am sorry to say you might just have to buy a 10" rough toilet.
New closet flange over old? shazapple Plumbing 4 08-31-2011 08:39 AM
Closet flange too high dank Plumbing 8 04-14-2010 01:23 PM
Closet flange gap kgifford Plumbing 5 03-12-2010 08:22 AM
No-Hub Cast Iron Closet Bend / Closet Flange lazypants Plumbing 10 06-11-2009 10:48 AM
Toilet closet flange kensington Plumbing 5 04-27-2008 08:19 AM
