Offset Bath Sink - Is This Okay? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-22-2012, 09:23 PM   #1
Send a message via AIM to chsitko Send a message via Yahoo to chsitko
Offset Bath Sink - Is this okay?
Hi everyone, i replaced an old wall mounted bath sink with a vanity+sink. The sink drain no longer is directly in line with the drain, so i got creative in some of my plumbing. Im sure there is a product out there that would have made this simpler, but i couldnt find it at any of the local big-box stores. So my question is simply, is what i did okay?
chsitko is offline   Reply With Quote
Old 04-22-2012, 09:27 PM   #2
Rewards Points: 582
I have seen alot worse....it will work.. but could you swing trap other way to reduce fittings used...???
Old 04-22-2012, 09:32 PM   #3
Rewards Points: 13,468
I agree, it looks like that trap could have been turned 180 deg. and it would have worked.
Old 04-22-2012, 09:35 PM   #4
Rewards Points: 582
thats what i thougth but it may also need a 45 to work????
Old 04-22-2012, 09:45 PM   #5
In my ideal world, i would have had the J-trap turned 90 degrees so that it was facing towards the wall. This would have maximized the space on either side of the drain. The main problem i had was because i needed a 2 x 90 degree bend to bring the pipe in-line with the drain. The big box stores only had straight couplings which pushed it out to far. I did find 90 degree and 45 degree couplings online so i might order a couple of those to clean it up.
The Following User Says Thank You to chsitko For This Useful Post:
ben's plumbing (04-23-2012)
Old 04-23-2012, 08:19 PM   #6
I was surprised to find the Lowes by my work had both 45 & 90 unions. So i picked up a 45 and here is the end results.
Old 04-23-2012, 08:21 PM   #7
Much better and less likly to plug up.
Old 04-23-2012, 08:54 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
We are only allowed one slip joint connection on the outlet of the p-trap.
I would have had to do it with this : http://www.hardwarestore.com/media/p...2_front200.jpg
And this : http://www.acetogo.com/photo/product/42266.jpg
and then this : http://mobilehomepartsstore.com/Merc...001/135801.jpg
Yours will work fine. Looks much nicer that way. Great job.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Old 04-23-2012, 11:42 PM   #9
Rewards Points: 582
excellent job needless to say it looks much better..
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 08:29 PM
Offset Vanity Tops miltoda Building & Construction 0 12-19-2011 03:29 PM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
