Off-white Debris On The Washer Inlet Screens - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-17-2013, 02:13 PM   #1
Dave Sal's Avatar
Rewards Points: 574
off-white debris on the washer inlet screens
Getting a new washing machine today. While moving the old one out of the way and removing the water supply lines I noticed that the screens on the back of the washer inlets were covered with an off-white, brittle plastic like substance. I've been recently having water heater issues as well, and after reading up on this now believe that the water heater dip tube is to blame for both of these issues. I first noticed that during a shower the water is warm as usual but after a few short minutes it gets cooler and I have to adjust the water temperature. That leads me to believe that it is a corroded or cracked dip tube as the likely cause. Does this sound right?
off-white debris on the washer inlet screens-washer-inlet-screen.jpg   off-white debris on the washer inlet screens-debris.jpg
Dave Sal is offline   Reply With Quote
Old 02-18-2013, 12:31 PM   #2
It is a plausible explanation for the hot water inlet but doesn't explain debris in the cold water inlet.
Bob999 is offline   Reply With Quote
Old 02-18-2013, 12:55 PM   #3
Dave Sal's Avatar
Rewards Points: 574
Good point.
Painting white martinigirl Painting 3 04-26-2009 07:24 PM
Insect/ debris filter for air inlet Ernest1 HVAC 8 02-06-2009 02:03 PM
Off White Trim/Base/Crown with White Ceiling/Doors? StyxTx20 Interior Decorating 4 12-15-2008 08:54 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Better way to protect portable generator inlet? IvoryRing Electrical 7 05-30-2006 08:30 PM
