Old 05-13-2007, 12:44 PM   #1
Lightbulb Off the wall question
I have a copper supply line that runs the length of a crawlspace to an outside faucet at the front of the house - Living in upstate NY about every five years or so I don't get the water shut off on the first or perhaps second below freezing night......anyway the pipe has burst again and in the past I crawl in and I solder in a new piece.....do PVC supply lines also burst or are they more forgiving.....? Thinking that I could replace the copper run...?
Thanks,
Rick
Rick Bruner is offline   Reply With Quote
Old 05-13-2007, 01:25 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
A. I'm not a pro plumber...just a 50-year+ DIYer.
B. Copper will freeze and burst. PVC will freeze and burst. CPVC will freeze and burst.
C. PEX, which is what most pro plumbers are installing here now, will freeze and expand but rarely burst and will return to its original shape. You will have to have transition fittings from copper to PEX and a PEX connection crimping tool (1/2" if that's what the water line is). It comes in flex line rolls and you can probably rent the crimping tool.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 05-13-2007, 07:46 PM   #3
Default Off the wall question
Mike.....
Thanks much - I had just heard of PEX but was not aware that it would "survive"- will check this out....much appreciate the help....!!
Again thanks,
Rick
More On This Topic
Crimp Beads for Jewelry
Crimp Beads for Jewelry by Expert Village
Ok so in order to put a clasp on tiger tail you need crimp beads. Crimp beads are very tiny and they come in silver and gold and copper and also other kinds of metals as well. And I will demonstrate how this works. Say this is the end of a necklace ok... Read More »
Hi, my name is Ella Seltzer for Expert Village. Okay, so this is what you need to make your floating bracelets. You need six Austrian crystals you could also use Foroski crystals, or any type of bead that catches your eye. In order to make a delicate... Read More »
Hello my name is Sabirah Parker I am one of the owners of Beadalicious located at 34 East Landgo Street in Baltimore, Maryland on behalf of Expert Village I like to welcome you back to creating beaded jewelry. We will continue with segment fourteen crimp... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be answering the question how do I fix a coolant leak. There are a lot of products that you can add to the coolant which will help seal small leaks in your coolant system. However if... Read More »
Hi! This is Diana for expertvillage.com and today we are making a copper plant hanger from copper refrigerator tubing so I would like to show you all the materials that you are going to need to make this particular garden hanger. I have some half inch... Read More »
knee wall question jscholl411 Building & Construction 7 10-10-2007 02:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 11:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 03:39 PM
Floor and wall tile question irlizard Flooring 21 07-20-2006 03:35 PM
One more wall question J187 Building & Construction 7 05-25-2006 07:57 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
