Old 07-10-2012, 06:25 PM   #1
off the shelf D/W inlet to sink question
thanks all I'm getting very close to putting my sink and D/W in I have a question about this little thing here...
the inlet for the D/W has a insert that cuts the diameter of the 1 1/2" pipe in half. Would not this cause a problem? I am leery that this would get clogged easy with stuff from the sink and slow down the flow even unclogged.
is this thing really gonna work ok ? if not what is the best option to make up something better.. THANKS!
petros151 is offline   Reply With Quote
Old 07-10-2012, 06:33 PM   #2
call me E
TheEplumber's Avatar
i'd get one without the baffle in it. Although it probably won't affect your flow any more then a strainer sitting in the drain
Old 07-10-2012, 11:01 PM   #3
Doing it myself
Alan's Avatar
We always use them.... if the drain starts to slow down and you don't have a baffle, the dishwasher pump will eject liquid vertically.
The baffle helps to keep the splash down. I prefer the baffle, others might not.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
Evstarr (07-11-2012)
Old 07-11-2012, 01:58 AM   #4
ok got-cha that makes sense I see how it is constructed to prevent that
thanks!
Old 07-11-2012, 03:12 AM   #5
I threw that away never thinking what it might have been good for! Lucky I guess that I ran the dw drain into the disposer! Thank you for improving my plumbing education!
Evstarr is offline   Reply With Quote
Stainless Steel Sink Question jamiedolan Remodeling 3 05-01-2011 08:35 AM
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 04:05 PM
floating shelf question typo Carpentry 9 06-17-2010 02:46 PM
Question about GFCI behind future kitchen sink ChrisDIY Electrical 5 02-18-2010 10:02 AM
Dishwasher water inlet valve question Schweinehund Plumbing 0 01-29-2010 02:37 PM
