Off-grid Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-22-2011, 12:03 PM   #1
off-grid plumbing
Hi everybody, this is Jeremy. I live in an off-grid house in the boreal forest of Manitoba, Canada. A few years ago I had a well dug and a waterline installed from the well to a 100 gallon tank on the second floor of my house. This is a gravity-fed system (cold water only) that works very well with the small amount of electricity that my solar panels produce.
Where I need advice is between the well pump and the tank. I recently split the line with a brass T-junction so I could run a garden hose directly from the pump. I have 1 1/4" poly fittings threading into the brass T. Am I supposed to use Teflon tape on those threads? I did, then tightened the fittings to what felt almost like the breaking point, although there was still some thread remaining. These threads have a drip when the pump is running. Should I perhaps omit the teflon tape and see if I can thread those poly fittings all the way before they break?
jstevens66 is offline   Reply With Quote
Old 07-23-2011, 10:56 PM   #2
Registered User
Rewards Points: 526
Welcome to the forum! I'll move you to "Plumbing" for a better response than in "Introductions".....
Gary
Old 07-23-2011, 11:45 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Teflon tape is the correct way to do it.
Without it, you will definitely have leaks
Did you wrap it the proper direction?
How many wraps? I usually give 5-6 wraps of the cheap stuff, and 3-4 of the really good stuff.
Don't break it .
Journeyman Plumber
Old 07-25-2011, 07:04 AM   #4
Plumb or Die!
Use teflon tape AND a teflon based pipe dope. Poly fittings are easily overtightened, as well. Crank them on hand tight, and only wrench one more turn, max.
plumber666 is offline   Reply With Quote
How to find plumbing distributors for plumbing invention? Timster Plumbing 14 03-14-2014 08:55 AM
Grid power loss indicator ? Roy Rowlett Electrical 1 03-20-2010 09:53 PM
ALOT Of Help Needed for Plumbing ~FYE~ Plumbing 4 09-22-2009 12:28 AM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 06:25 PM
