Old 02-21-2004, 01:37 PM   #1
Bob Nau
Guest
Posts: n/a
Odor under the sink
We recently bought a new home (June). Starting in September we began smelling a strong odor in the Cabinet under the sink in the downstairs bathroom. The odor is similar to Mold.
We have nevered stored anything but dry linens in this cabinet.
Our builder has done the folllowing to address this problem - without successful results:
1). Changed the vent cap under the sink
2). Changed the trap under the sink.
3). brought in someone with a device to measure Moisture in walls and floors. None was detected.
Does anyone have any idea what could be causing this odor ??
Thank you for your help.
Old 02-22-2004, 01:32 PM   #2
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
Odor under the sink
Moisture could have gotten trapped in the walls during the build out. I'd tear out the wall floor cabinet anything...
-Grumpy
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 05-14-2013, 07:08 PM   #3
Odor under the sink
Is this a brand new house?
Is the odor in any area adjoining the bathroom? Strange that the odor appeared after 3 months.
I'd call the Health Dept. in your city and ask if they or someone can do an air quality test.
I was a property mgr once and occasionally had to track down and eliminate odors.
Startingover is offline   Reply With Quote
Old 05-14-2013, 07:50 PM   #4
Master Plumber
Javiles's Avatar
Odor under the sink
If you suspect its from the sewer have a smoke test performed.
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 05-14-2013, 07:54 PM   #5
Jmayspaint's Avatar
Odor under the sink
What's a smoke test? I have a similar issue, pretty sure it's sewer gas, but my wife says it smells like something else to her, moldy
Jmayspaint is offline   Reply With Quote
Old 05-14-2013, 08:36 PM   #6
Master Plumber
Javiles's Avatar
Odor under the sink
Smoke test is when we pump smoke in to the plumbing system any smoke inside the building indicates that sewer gases are entering the house at some point, examples bad toilet seals cracked or broken vent stacks no traps at fixtures, unused or old plumbing that was not capped or eliminated correctly and so on, you cant see sewer gas but you can see the smoke to find the source.
The Following User Says Thank You to Javiles For This Useful Post:
Jmayspaint (05-14-2013)
Old 05-14-2013, 09:51 PM   #7
Odor under the sink
Iam guessing trap seal is being pulled and allowing sewer gas into the home...what happens is when others fixtures are being used ..like commodes after a flush there is a problem with the way the plumbing was installed not enough vent ....smell.... ben sr
Old 05-14-2013, 11:09 PM   #8
Odor under the sink
Have your wife pour a bottle of ammonia down the toilet upstairs and flush it...
Wait and see if you smell it downstairs it may take some time..
The Following User Says Thank You to Ghostmaker For This Useful Post:
Startingover (05-15-2013)
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-19-2007 12:26 AM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 08:37 PM
