Odor - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-04-2010, 09:46 AM   #1
Bad odor coming from my shower drain. I have used Drain-O but didnt help.
k3021 is offline   Reply With Quote
Old 11-04-2010, 11:27 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Usually caused by a blocked or partially blocked vent pipe.
When water is drained through the system and the vent pipe is blocked or partially blocked, the draining water creates a siphon that pulls the water out of the nearest trap (t create a "vent"), allowing sewer gas back into the home.
Go up on the roof (or get someone else to) above that bathroom and clear the main vent stack pipe sticking up out of the roof of leaves, debris, birdnest, etc. by hand, Flush the pipe down with a garden hose.
If that doesn't solve the problem, you may have to use a heavy-duty plumber's snake down the vent stack to clear it and then flush it down.
Then your shower trap should hold water and prevent the sewer gas.
Good Luck!
Mike Swearingen is offline   Reply With Quote
Whirlpool dishwasher odor Captflx Appliances 8 06-26-2009 08:40 PM
odor from solar heat supplement system GrandmaStormy HVAC 1 03-08-2009 09:41 AM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
New Construction Odor Bewildered1971 Building & Construction 12 06-25-2008 09:39 PM
Sulphur odor in upstairs area ksherbak Plumbing 3 02-14-2008 03:39 PM
