Odd Shower Dripping - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2011, 05:46 PM   #1
Post
Odd Shower Dripping
In our master bath we have a stand-alone, single handle shower. Intermittently, after the shower is used, we get a delayed drip. Sometimes it's within a half hour and sometimes it happens several hours later. It may happen multiple times between uses. At times itís just a little water or at others itís two cups or more. Iíve changed out the cartridge without effect. Itís as if the verticle pipe to the shower head above the faucet is emptying out, but I canít figure out what is pushing the water up and out of that vertical pipe. Everything else in the house drains okay, so I doubt itís a venting issue.
zjohna is offline   Reply With Quote
Old 10-13-2011, 06:12 PM   #2
DIY staff
Rewards Points: 7,174
That is odd---is the shower tube directly above the handle or is it a rain shower in the center of the stall?
Old 10-13-2011, 07:38 PM   #3
AlbacoreShuffle's Avatar
What brand of faucet is it ?
AlbacoreShuffle is offline   Reply With Quote
Old 10-13-2011, 08:51 PM   #4
The tube is directly abpove the handle.
It is a Moen.
Old 10-13-2011, 08:53 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you on a city water system or private?
Journeyman Plumber
Old 10-14-2011, 07:15 AM   #6
City.
Old 10-14-2011, 09:07 AM   #7
Doing it myself
Alan's Avatar
Originally Posted by zjohna View Post
City.
Does your water heater have an expansion tank on top of it? Sometimes thermal expansion can cause those things to drip.
If it already has one, then check the air chamber to be sure it hasn't become waterlogged.
Journeyman Plumber
Old 10-14-2011, 12:12 PM   #8
It does not. I hadn't thought of that. Unfortunately, the way my utility closet is laid out, adding an expansion tank would be a major project. Any other suggestions?
Old 10-14-2011, 02:54 PM   #9
Rewards Points: 1,772
Mine does the same thing; no clue as to why or how but the valve is not leaking. I think it is some kind of siphon effect; perhaps as the water cools down in the shower head, it contracts, a vacuum is broken, and water drains from shower head?
bob22 is offline   Reply With Quote
Old 10-14-2011, 10:49 PM   #10
Doing it myself
Alan's Avatar
They can be installed anywhere on the cold water system.......
There's also a device made by WATTS called a governor 80 that allows the extra pressure built up from water expansion to dump out of the fill valve on one of your toilets.
I don't really like this option because it's wasted water, and I think it's a bit more expensive than an expansion tank.
Journeyman Plumber
Old 10-15-2011, 07:02 AM   #11
I have the same situation with my shower head,,always drips some after the valve is shut-off, not sure how much or for how long but its not a constant drip where I'd change the cartriage, I've just lived with it,, now it will be easier to accept knowing I'm not the only one.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 10-15-2011, 01:31 PM   #12
Thanks. I'm on a slab, so the only place I have open access to the water lines is in that utility closet. I'll look into the Gov 80. Thanks again.
Shower Mixer Valve : Misbehaving and Dripping freddy.carvalho Plumbing 1 01-15-2011 06:05 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
How to fix a dripping shower faucet? walds11 Plumbing 18 12-21-2009 07:17 PM
Water dripping in the shower??? Sellncars Plumbing 4 12-05-2009 08:07 PM
Shower Dripping Hot Water, Should I Shut Off Emergency Oil Burner Switch? bman46 HVAC 1 10-02-2007 02:04 PM
