Odd Hot Water Circulator Path - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2014, 10:02 AM   #1
Rewards Points: 45
Odd hot water circulator path
I purchased a house that was built in 2002 that has two 40 gallon hot water heaters in the attic with a hot water circulator. The circulator works, but it only appears to work with the bathroom farthest from the hot water heaters. Is that possible? Did the original homeowner go cheap and only use it for the farthest bathroom? The kitchen sink which is very close to the hot water heaters takes 20+ seconds for hot water, while the farthest bathroom is instant. The issue doesn't bother me, but it does make me curious. Thanks in advance.
Austin83 is offline   Reply With Quote
Old 12-20-2014, 10:37 AM   #2
MarginallyQualified
Rewards Points: 2,464
Of course. That's the only water user than needs the extra help.
Old 12-20-2014, 12:32 PM   #3
Rewards Points: 45
Thanks for the reply. I had just assumed that circulator would allow all hot water faucets to have quick access to hot water.
Old 12-20-2014, 02:43 PM   #4
Rewards Points: 1,700
Not unusually to just do it to the most distant bath only.
Old 12-20-2014, 11:48 PM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 984
If piped in correctly and the system is looped properly you should have hot water on demand at all hot water fixtures
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-21-2014, 08:34 AM   #6
MarginallyQualified
But like 99% of homes and fixtures...
the house pressure should be adequate without pump assistance
and the distance from the WH to the faucets is modest.
That last factor (distance) is the problem the OP has
but only with one of probably 5 faucet sets
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-09-2014 12:40 AM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 01:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
