Odd Cast Iron - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2012, 05:28 PM   #1
odd cast iron
Our toilet gets clogged half the time it gets flushed.
I'm thinking replacing the cast iron with pvc should help
the problem. It appears to be a unique piece of cast iron.
the toilet flange sits in the regular position.
It immediately takes a 90 degree turn to head to the stack.
Right after the turn a 1 1/2" enters the cast iron at a 45
degree angle for the shower drain.
Any ideas????
Last edited by retiredmgn; 02-04-2012 at 05:28 PM. Reason: trying to get a picture up.
retiredmgn is offline   Reply With Quote
Old 02-04-2012, 05:35 PM   #2
Rewards Points: 14,312
Should have no effect on the toilet draining.
#1 Any and all cast iron should have been removed and replaced years ago.
More inclinded to think it's the line it's self is plugged or there's something stuck in the toilets trap it's self (inside the toilet). Very common problum.
Remove the toilet and lay it down and see if something rattles or is blocking the drain.
Old 02-04-2012, 05:43 PM   #3
image attempt
Old 02-04-2012, 05:46 PM   #4
Even replaced the toilet last year. Have had a snake way the past the join to the stack.
I didn't want to have to say it but my poops go down without a problem. Mother, on the other hand consistantly plugs up the toilet.
Old 02-04-2012, 05:46 PM   #5
Rewards Points: 582
how old is commode.....plumbing my need replaced but commode may need replaced as well...
Old 02-04-2012, 07:38 PM   #6
GC/Master Plumber/Mech
Rewards Points: 560
Did you snake the drain?
If so what size snake did you use? If you used anything less than 1/2" with a cutter head then you didn't really snake the line.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 02-04-2012, 07:54 PM   #7
Try and explan it this way to her. If you did not eat it or it does not come off the toilet paper roll but it in the trash can.
If she is flushing personal items or things like paper towels down the toilet it's time to let her start learning how to work on it.
Old 02-04-2012, 08:02 PM   #8
Rewards Points: 560
Yes those white mice can catch on the inside of the cast.
Old 02-04-2012, 08:04 PM   #9
Not like that at all. We are old, retired folks. We know what goes in a toilet.
When I replaced the toilet last year I ran my arm down to the join in the stack. No obstruction. I'm only hoping pvc will have less drag and perhaps solve the problem.
Old 02-04-2012, 08:06 PM   #10
Rewards Points: 560
Do you folks use the handi wipes?
Old 02-04-2012, 10:44 PM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
So why are we comdeming any and all cast iron in this situation?
Ive seen plenty of old cast iron pipes that have been around longer than me tht are in better shape than me!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-04-2012, 10:50 PM   #12
Plumber
TheEplumber's Avatar
Rewards Points: 922
I agree! Yes, it will eventually fail, but probly decades from now
The Following User Says Thank You to TheEplumber For This Useful Post:
plummen (02-04-2012)
Old 02-04-2012, 11:54 PM   #13
DIY staff
Rewards Points: 7,174
Two fairly common causes---a sagging toilet pipe--pitched wrong--
An obstructed vent--not allowing air into the pipes---both fairly easy to test
Old 02-12-2012, 05:33 AM   #14
PoleCat's Avatar
Rewards Points: 1,652
I am going to throw this in just in case it has any bearing. I worked for a number of years in retirement communities and have done battle with countless clogged toilets. Hard water was the culprit many of the times. These toilets relied on the holes around the rim of the bowl to release much of the water and as they started to rock up the "dump" of water was insufficient to trigger a good flush. I would diagnose calcium or clog by dumping in a 3 gal bucket of water. Muriatic acid would set em straight again.
PoleCat is offline   Reply With Quote
Bathtub Recommendations - Cast Iron or other? HandyFrank Plumbing 5 10-25-2011 03:25 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 04:41 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
