Obsolete Single Lever Shower Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2011, 12:19 PM   #1
Question
I have an American Standard Ceramix SLSF w/diverter (Mod.# 2000.400/402 w/an R-120 valve)) that I am looking to replace. Unfortunately today's models do not have the diverter assembly as part of the valve housing just above the valve as this one does. Rather than replace the entire housing I thought that I could remove the diverter assembly which I am hoping is screwed into the housing and put a brass threaded plug in that hole. Then buy a new tub spout with a diverter in the spout. I am assuming that when I turn the water on the gravity flow of water would send the water to the spout & not the shower head and that would be it. But if that is not the case I would also add a shower head diverter as well to control where the water comes out by controling each end.
Lastly, before doing all this does anyone know of a replacement trim that would replace the trim that I have. I contacted American Standard and they were no help at all.
Johnny U is offline   Reply With Quote
Old 11-11-2011, 01:04 PM   #2
DIY staff
Rewards Points: 7,174
Why are you trying to salvage such an old obsolete mixer?
Is there something special about it that makes it worth keeping?
Old 11-11-2011, 01:10 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yow...the cost of a replacement.
XXX
Old 11-11-2011, 01:13 PM   #4
DIY staff
You seen the cost if replacement parts lately?
Old 11-11-2011, 01:17 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I try not to think about it!
But if I continue to work for nothing and pass that savings on to the customer then everything will be fine. Won't have any food but the customers will be happy.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
oh'mike (11-11-2011)
Old 11-11-2011, 01:19 PM   #6
Moen still makes a tub and shower valve with the diverter in the valve.
http://www.needplumbingsupplies.com/...s.asp?id=11700
Old 11-17-2011, 03:44 PM   #7
Smile
Try this trim kit with R120 Valve / replaces the one you have and works very good /
Ref> I have an American Standard Ceramix SLSF w/diverter (Mod.# 2000.400/402 w/an R-120 valve)) that I am looking to
Thanks[/quote]
Hello / check this one from AMSTD / / // this would be your replacement trim kit
Check this link . / / http://www.americanstandard-us.com/s...#componentR120
Ceramix bath shower with R120 valve / this is the replacement for the one you have / visit the AMSTD web page /
mrfix is offline   Reply With Quote
Old 11-17-2011, 03:56 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
COMMUNITY SERVICE ANNOUNCEMENT:
Did you guys realize that even after you make a post such as this one you can still go back and EDIT the content to make it more American and understandable? Your EDIT BUTTON appears in the lower right hand corner of the frame.
Just sayin'!
Plumbing single handle shower zrooster99 Plumbing 5 02-26-2011 09:45 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Faucet Drain Lever Installation DK75 Plumbing 3 05-21-2008 10:08 AM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 08:08 AM
