Oatey In-line Vent Position - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-22-2011, 11:41 PM   #1
Oatey in-line vent position
Hello all,
First time post & not a plumber!
I'm looking for help with the installation position of an Oatey in-line vent. I've installed a sink pump system that pumps directly to the septic line in basement. The pump system requires a vent line. I couldn't easily attach the vent to the existing vent system in the house. I tried this Oatey in-line vent however the water in the sink does not drain with it installed. If I remove the the vent it flows as it should. I have the vent installed fairly high to the ceiling and thought maybe it needs to be lowered. The pump has a flow check valve and is hard piped to the existing drain. The sink has a trap as normal. I've attached a simple sketch of my situation and was hoping someone here could provide some assistance. Thank you in advance for any help.
Adiadog is offline   Reply With Quote
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 11:18 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 06:17 PM
Capacity loss with line size Einride HVAC 1 06-29-2009 04:10 PM
sewer line Master Brian Plumbing 3 05-25-2009 01:53 AM
Water Coming Out of Vent Line?? dost559 Plumbing 3 06-11-2008 09:50 AM
