O2 Barrier For PEX - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2011, 05:10 PM   #1
Rewards Points: 150
O2 barrier for PEX
Ok, I had another thread detailing my difficulty in finding 1" O2 barrier PEX locally. So I had a brilliant idea....
The difference between O2 barrier and non-barrier PEX is, duh, the O2 barrier. Manufacturers use EVOH usually. This is glorified Saran Wrap.
Why not just install regular PEX, and wrap it in GLAD or Saran-wrap??? Won't that provide O2 protection??? I only need like 6 feet- a managable amount to wrap by hand.
gbwillner is offline   Reply With Quote
Old 11-14-2011, 06:01 PM   #2
Why not just use copper for the short section?
Bob999 is offline   Reply With Quote
Old 11-14-2011, 06:42 PM   #3
Rewards Points: 150
Fair question. The answer is cost- since there is galvanized steel for a majority of the primary circuit I will need 4 dielectric unions, 4 elbows, 4 female to cu connectors and 4 ccu to male connectors for 1" pipe. That's like $80 for the 2 secondary circuits vs. $10 for the PEX.
Old 11-14-2011, 06:44 PM   #4
Just call me Andrew
Rewards Points: 1,020
can you just use 3/4" for 6 feet?
or make 2 parallel runs of 3/4" so you have no flow loss.
Andrew
secutanudu is offline   Reply With Quote
Old 11-14-2011, 07:26 PM   #5
So use 6' of galvanized pipe.
Old 11-14-2011, 07:46 PM   #6
Rewards Points: 150
can't. Not just because of the similar cost issue, but also because of the bulk of the pipe in the limited space I have remaining.
Old 11-14-2011, 08:42 PM   #7
Rewards Points: 150
vapour barrier on ceiling of bathroom? wilsonfrench Building & Construction 20 01-29-2012 09:08 PM
Clearance of Duct to Vapor Barrier mkturn HVAC 0 02-21-2011 01:41 PM
Reattach gutters--caulk leak barrier? soubriquet Roofing/Siding 6 04-16-2010 09:38 PM
Should I use a vapor barrier on each side? Hossenfeffer Building & Construction 3 04-09-2010 11:12 PM
Moisture Barrier for Partially Below Grade Grouted CMU Wall Fire4Effect Building & Construction 4 07-06-2009 12:51 PM
