Old 10-11-2009, 10:04 PM   #16
Yoyizit's Avatar
A O SMITH gas water heater problem
Originally Posted by redsky01 View Post
we have around 30 units in our community all with the same heater...have heard all of them having issues on and off
Bad batch of heaters?
Impure NG in your community?
Improper installations?
Maybe you need a community class action lawsuit?
Replacing it at 3 years would be a record for the replacement age data that I have.
Old 10-11-2009, 10:59 PM   #17
Did you clean the flame arrestor that you can't see under the heater? If all you have done was clean the plastic screen that you can remove then you haven't been fixing it. In the very center of the bottom of the heater they have a ceramic disc which you need to suck all the dust out of. A.O Smith was giving out a special vacuum attachement made just for this, I have one. you can make one with pvc pipe and an elbow if needed. you have to get all that dust from the flame arrestor because it will cause the heater to not get the right air to gas mix and over heat, Which will make it go out. It is a very well known problem with your heater.
plumber Jim is offline   Reply With Quote
Old 10-12-2009, 12:03 AM   #18
Thanks for the quick replies !
I have tried cleaning the plastic screen at the bottom....
on a different note for the 1st one year there was no plastic screen....I never knew until the first time I had issues...
I have not vaccumed all the way till the center but have put in a vaccum pipe a little through the slots at the bottom....I cut the pipe on the end of an old vaccum and that helped me in reaching inside (not all the way to the center...)
the problem with the pvc pipe reaching inside is that I have a plate with a rim on the outside bottom of the heater....so have very little clearance for putting a pipe in for cleaning.....
I am so mad at the moment....
Horrible heater ...useless company !
Plumber Jim, can you please let me know if AO smith openly accepts that there is a defect in this heater ?
redsky01 is offline   Reply With Quote
Old 10-12-2009, 12:48 PM   #19
Yoyizit's Avatar
A design defect, and the bandaid is this vacuum gadget?
http://www.ripoffreport.com/
Old 10-14-2009, 01:04 AM   #20
hello,
can you please let me know what is with the ripoff report ?
Thanks,
Old 10-14-2009, 04:50 PM   #21
Yoyizit's Avatar
hello,
Thanks,
People who bought this heater might feel AO Smith ripped them off.
Especially in that AO makes a special tool to lessen this problem [thereby acknowledging a design problem] rather than fix the water heater design or make some kind of customer restitution.
If this procedure is normal maintenance for this heater, I guess it should say it somewhere in the owner's manual or installation instructions.
Old 12-15-2009, 03:31 PM   #22
Hey guys and gals, first off I used to be a plumber but am now working towards a career in website design. I just registered here at diy because I'm having the same problem of the pilot going out in my '04 A.O. Smith 40 gal. water heater and found this topic pretty helpful. Thanksgiving, the in-laws were over the house and we notice no hot water in the evening. Well I went down and got her fired back up and all was well...for a day or two. A few days later we had a lot of wind here in OH and the wife and I woke up to cold water. Huh, went down and got the pilot going again. Since then it's been going out pretty much every day. That is kind of scary considering that if the gas valve doesn't end up shutting off for whatever reason, gas is going to get into the room. We're in a newer community here so I suspect a lot of the houses were fitted with these things. I'm going to make some sort of extension and vacuum out the center of the heater as has been suggested. I know the screen at the bottom is nice and clean. I'll let you all know if this fixes the problem. I would think that if the thermocouple has gone bad, it would not light the pilot at all. Ya know, I got out of plumbing for a reason...
mikewuzaplumber is offline   Reply With Quote
Old 12-31-2009, 03:29 PM   #23
Unhappy
I have a 40 gal AO smith Promax that just starting acting up today - pilot stays on but you need to turn the thermostat up above where it's been set to get the main burner to light . I've emailed AOSmith but no reply as of yet - It's frustrating when you buy what you think is a reliable brand/product.
Any ideas on whether cleaning/vacuming will help?
brewchaz is offline   Reply With Quote
Old 01-01-2010, 07:02 PM   #24
Are you saying that the water is cold and the main burner isn't going on?
If yes then, No cleaning the flame arrestor isn't the answer for that one. It would mean that the gas control valve is bad.
Old 01-20-2010, 11:36 AM   #25
Ok My landlord baught the A.o. Smith water heater and it was fine. Then six months ago it started going out. I would light the pilot and before it would tottaly heat the water it would go out. I have learned the easy way thank goodness. YOu have to vacumm out the bottom of the water heater at least every 3 months. There is a circle behind the black little screen on the bottom. I took a water hose and taped it to my vacumm hose taped one end then cut a little whole on the top that way I could vacumm out the little round screen thing hidden right in the compartment behind the screen . Sounds confusing but if you look at this website it will show you. All you need is an atatchment or make your own and a flash light. Girls if I can do it you can too.
http://www.broomfieldplumber.com/wat..._cleaning.html
shaliesmom is offline   Reply With Quote
More On This Topic
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
I'm Jay Donnelly for Expert Village and today I am going to show you what you might need in case of a flood emergency. Okay the next step is house preparation. Secure your house. You want to go around your house and you want to shut off utilities such as... Read More »
Before you buy a house, it is a good idea to either inspect it yourself or hire a professional to do it for you. If you do not know what to look for, you may end up with repairs and problems you did not expect. Here are some tips on how to inspect... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
A space heater can save money on gas and electric bills because it heats only a small area and efficiently converts almost all of its energy into heat. However, heaters can pose a serious danger from fire and toxic air pollution. Reduce these risks by... Read More »
I would like to relocate the flue for my gas water heater Git HVAC 12 04-23-2008 10:37 PM
gas water heater testing MrLinux Plumbing 11 04-14-2008 08:07 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
Water Heater troubles AZJD Plumbing 16 01-11-2008 06:32 AM
water heater issues Missydo Plumbing 17 04-05-2005 10:31 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
