A.O. Smith Gas Control Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2012, 03:22 PM   #1
How long does it take to replace the gas control valve on an AO Smith Power Vent Water heater?
selaeration is offline   Reply With Quote
Old 01-02-2012, 03:52 PM   #2
MarginallyQualified
Rewards Points: 2,464
Mostly... it will depend on whether the tank drain valve boogers up or not.
Without that hiccup (more and more common with the crapola plastic valves that should be replaced at install)... not long at all.
See that threaded part on the back side? That's it.
(Change out the thermocouple at the same time)
hth
Old 01-02-2012, 05:21 PM   #3
Rewards Points: 1,294
Get the new one prepped to go in. (tape, dope, etc). unscrew the old one and spin the new one in fast. Don't even have to drain the tank. Very little water will come out due to very little air getting in. I do it this way all the time. Seems like more now than in the past.
danpik is online now   Reply With Quote
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Resource for understanding gas valve? darsunt HVAC 19 02-03-2009 11:08 PM
How to check gas control valve? downunder HVAC 8 02-03-2009 07:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
