A.O. Smith 50 Gal Water Heater....Gas Smell/CO Detector - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-09-2012, 05:00 PM   #1
A.O. Smith 50 Gal water heater....Gas Smell/CO detector
Live in a condo unit and after taking long, hot showers or if both showers are in use, the utility closet that contains the water heater has a strong gas smell which also sets off the Carbon Monoxide detector. After about 5-10 minutes both the gas smell as well as the detector stops and goes away.
What could be causing this and hoe do you fix it???
swmrdak79 is offline   Reply With Quote
Old 07-09-2012, 05:45 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by swmrdak79 View Post
Live in a condo unit and after taking long, hot showers or if both showers are in use... how do you fix it???
Use less hot water.
One shower at a time and shorter time under the water.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
AO Smith GPSH water heater in System Lockout mode but resets itself gpatalin Plumbing 0 12-09-2010 09:09 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
