O-ring Seal Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-08-2011, 11:16 PM   #1
Rewards Points: 91
o-ring seal problem
Spray wand attaches to bottom of faucet using 2 o'rings. it leaks and I cant fine replacements. The 2 local shops that are both known to be very well supplied, dont have this exact size. The one they have being slightly larger thickness, so id is the same, od is just slightly larger and it prevents coupling. What can I do to stop the leak?
tks,
p
paulmars is offline   Reply With Quote
Old 12-08-2011, 11:47 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 564
You need the proper o rings. Keep searching at good plumbing supply houses or call the manufacturer. Do a web search too.
Door latch / seal problem trswyo Building & Construction 4 08-19-2011 07:27 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Toilet Seal Leak Problem boblgamble Plumbing 4 06-21-2008 10:42 AM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
