Now Onto The Shower... - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-12-2012, 11:46 PM   #1
Rewards Points: 77
Now onto the shower...
I have built a bathroom in the basement, subfloor, and tiles are in, toilet is in (thanks Oh Mike!), now onto the shower.
I have a cement pan with liner and backer board up. Unfortunately I made the doorway too small and don't have the room to put backer board on the inside of the door frame (where the door hinge would be set).
Am I able to staple Metal lath to the inside of the door frame, then thin set mortar, then tile?
Other solutions are welcome! Unless they involve starting over...
shorteared is offline   Reply With Quote
Old 08-12-2012, 11:57 PM   #2
Rewards Points: 77
As you can see I have gotten to the point of using Redgard and was just about to tile (after another coat of Redgard), but thought I may be doing something wrong. I have simply taped the 2x4 frame using proper fiberglass mesh tape and then put a coat of thin set on and a coat of Redgard.
So again.... Should I put metal lath over this then thin set, Redgard, then tile?
Old 08-13-2012, 11:59 AM   #3
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I admit I'm blond, but I'm totally confused by your pic.
Is it right way up?
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 09:03 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
