Old 10-31-2012, 02:01 AM   #1
Novice Garage disposal replacer here.
My old one has an electrical cable which easily plugs into a wall socket under the sink. My new one on the RIGHT...no cable. Can i remove the cable from the old one on LEFT? If so, i could use some instruction. Ty in advance for all who take time.
Novice Garage disposal replacer here.-forumrunner_20121031_010031.jpg   Novice Garage disposal replacer here.-forumrunner_20121031_010138.jpg
41Souls is offline   Reply With Quote
Old 10-31-2012, 04:36 AM   #2
Yes just swap them over.
You should be able to disconnect the wire nuts and green ground wire through that square hole. The thick rubber cable looks like it will twist / turn and come out.
jammin06 is offline   Reply With Quote
The Following 2 Users Say Thank You to jammin06 For This Useful Post:
41Souls (10-31-2012), oh'mike (10-31-2012)
Old 10-31-2012, 08:54 AM   #3
try to pop off the metal cover by removing the screws, you should be able to remove the wires and swap them over to the new one.
pwgsx is offline   Reply With Quote
The Following User Says Thank You to pwgsx For This Useful Post:
Old 10-31-2012, 10:58 AM   #4
Thank you guys. GOt it done!
Old 10-31-2012, 11:06 AM   #5
Finished look
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
