Novi American Whirlpool Won't Turn On - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2011, 04:43 PM   #1
Novi American Whirlpool won't turn on
Hi, I have a Novi American whirlpool that won't turn on. Checked the breaker and it's fine. Also opened up the unit and the tubing to the on/off switch is connected. My son was using it last before it stopped working. Is it possibly that a toy got sucked and is causing it to not turn on? Any other ideas? Thanks!
cvanderhoef is offline   Reply With Quote
Old 09-25-2011, 07:52 PM   #2
DIY staff
Rewards Points: 7,174
It is plugged into a gfci circuit-----(like the outlet near a sink)
Often the outlet is under the tub or exposed in a room near the tub---If you have opened the access panel unplug the pump and test that outlet---
Old 09-25-2011, 08:04 PM   #3
I don't believe there is a GFCI circuit, it's got it separate breaker at the junction box.
Old 09-25-2011, 08:41 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
The plug at the whirlpool itself doesn't have the reset and test buttons on it? As mike said, it's supposed to be a GFCI, but I don't know the electrical code on location of the things. I've seen plenty that are underneath a bathtub.
Journeyman Plumber
Old 09-26-2011, 09:27 AM   #5
Oh really? Everything I had read said it would have either a GFCI or a breaker for it. I'll take a look under the tub and see if there is a reset on it. Thanks!
Old 09-26-2011, 09:38 AM   #6
DIY staff
I have found the GFCI outlet hidden in odd spots--once behind the toilet---another time in a closet behind the tub---another time in a bedroom near the tub.
Old 10-03-2011, 01:17 PM   #7
I opened it up and I didn't see one but there is so little room down there. My guess is it's on the other side of the motor. It's so cramped I can't even see where the motor is plugged in or the cord for it.
Old 10-03-2011, 09:07 PM   #8
Doing it myself
Alan's Avatar
That's why I would never put a whirlpool in my own house. The only required access for the thing is big enough for the pump to go in and out. Let alone a guy get even half an arm in there to try and take it apart while he can't even see what he's doing.
Journeyman Plumber
Can't get unit to turn on need electrical help please-wiring diagram included igotshocked Electrical 33 01-30-2014 05:13 AM
Kohler Whirlpool wont turn on swieder Appliances 0 10-04-2009 11:54 AM
Do I need to turn off water heater? creamaster Plumbing 8 08-19-2009 11:07 AM
Fan and A/C unit won't turn on cadmanim HVAC 1 06-22-2009 02:49 PM
90 degree turn in horizontal 3" main drain wildbilly Plumbing 2 03-14-2009 05:52 PM
