Not Using Garbage Disposal With Sink Intended For One - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2011, 05:24 PM   #1
Rewards Points: 1,062
Question
not using garbage disposal with sink intended for one
i bought this aluminum sink cheap at a recycle 2nd hand place and intend to use it as a mop basin in my shed.
however, it is intended to be used with a garbage disposal, which i am not needing.
so, my question is: how do i adapt this 3" hole to 1.5" or 2" PVC pipe? i have 2" pipe not sticking out of concrete, which i can obviously easily adapt to 1.5".
pics attached.
thanks
not using garbage disposal with sink intended for one-sink1.jpg   not using garbage disposal with sink intended for one-sink2.jpg   not using garbage disposal with sink intended for one-sink3.jpg
Old 07-18-2011, 05:48 PM   #2
Unscrew the disposal adapter and install a sink drain kit:
GottaFixIt is offline   Reply With Quote
The Following User Says Thank You to GottaFixIt For This Useful Post:
amakarevic (07-19-2011)
Old 07-18-2011, 06:12 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
i bought this aluminum sink cheap at a...
Stainless steel sink actually.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 07-19-2011, 06:53 AM   #4
Rewards Points: 1,500
Some brands of disposer drain fittings require stretching and removing a thin springy C-shaped "ring" to dismount from the bottom of the sink.
Sometimes the parts are "glued" in place and prying them apart can deform the bottom of the sink and make it hard to avoid leaks with the new fittings. Moderate heating with a torch may help.
AllanJ is online now   Reply With Quote
Tags
sink drain
garbage disposal under double sink debiasio Plumbing 3 01-02-2015 11:27 AM
Garbage Disposal to match sink FF_Thor Plumbing 4 03-10-2011 09:05 AM
Garbage Disposal and Backed up Kitchen Sink [Video Included] HowToGuy Plumbing 5 02-27-2011 07:30 AM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 06:24 AM
garbage disposal /double kitchen sink redroc25 Plumbing 7 11-15-2009 05:32 PM
