Not A Typical Plumbing Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2011, 02:41 PM   #1
Rewards Points: 211
Not a typical plumbing issue
I have a cooling contraption/pipe that needs a certain layout in order to fit in certain space and provide more surface of contacting with the air in order to optimize its cooling properties. The previous one has a too big a hole and is made of aluminum, the following is a pic of it:
It is for use in small motorbike, and it is going to carry automotive coolant (the type that is non-harmful to aluminum). So basically I need to make a pipe of the right size (diameter) that is easy to shape and bend (maybe with heat or some pipe bending tool, or a combination of both), and also will be durable and withstand road environment. Any suggestion would be greately appreciated.
tk
tk3000 is offline   Reply With Quote
Advice/thoughts on plumbing issue mrmagoo_83 Plumbing 10 03-26-2010 08:43 AM
unusual floor drain backup issue kindofahandyman Plumbing 4 03-10-2010 10:48 AM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Plumbing Issue construction wife Plumbing 3 05-25-2008 11:42 AM
missed the plumbing in the slab!!! fauer Plumbing 7 03-03-2008 07:37 PM
