06-15-2010, 07:05 AM
#2
not sure what is happening here
That doesn't look right at all. Drain water should not be coming out the side of the house!!!! No way to tell what you have from here, I suggest a plumber.
06-15-2010, 07:17 AM
#3
Could that be a outside clean out that the cap or pipe rotted out??
06-15-2010, 09:16 AM
#4
Ok. I can close that with some thing.. then I am worried about how the drain water will behave in that situation.
#5
I agree with you.
06-15-2010, 09:30 AM
#6
Xtreme DIY'r
Yeah, seems like a clean out that rotted out
Is there a basement below ? Or is this on a slab ?
If it was the only drain you would see a LOT of water coming out when the sink was on
Washer water - dishwasher or washing machine ?
Test - plug it up with a rag & turn the kitchen sink on full blast
06-15-2010, 09:34 AM
#7
If it was the only drain you woudl see a LOT of water comingout when the sink was on
This is on Slab.
Let me understand you.. you say - 1) close the cleanout with a rag (?).
2) open Kitchen water on full blast.
But how do I ensure that problem is solved ? does the water come out from some other place ? or from the kitchen itsef ?
06-15-2010, 10:51 AM
#8
Household Handyman
IMO-Picture #2 shows a "clean out access" with a plug with square cap broken off. This is allowing backed up drainage water to come out of this cap. The problem is you have some sort of back-up in your drain line. IF you're drain line was clear and working correctly the water would not be coming out of this clean out even with the cap removed. The plug needs to be removed without breaking it apart any more, the line(s) needs to be cleaned, and a new plug installed. Unless you have experience with this--call a plumber. David
06-15-2010, 10:58 AM
#9
Thank you..
1)Is there a way I can remove the plug without breaking it ? Any tools suggested ? I am not experienced guy.
2) If I open the plug, would I be able to clean the main line which looks like choked.
3) Would you suggest me to drop some drain liquid from the kitchen sink to loosen the choke ?
Please help.
06-15-2010, 11:43 AM
#10
Xtreme DIY'r
Originally Posted by cprao
This is on Slab.
The Test would be to see if the drain is clogged up enough for water to back up into the sink
If you do get the cover off I would toss a hose in there to flush it out if your water pressure is high enough
06-15-2010, 11:47 AM
#11
The Test would be to see if the drain is clogged up enough for water to back up into the drain
Me to
06-15-2010, 01:21 PM
#12
Ok. Let me first close the drain and see whether water can be backed up to sink or not ?
06-15-2010, 04:07 PM
#13
No, that's pointless. You already know two things:
1. You have a broken cleanout plug that needs replacing.
2. You have a blockage somewhere downstream of that cleanout.
# 1 is minor, you can just replace it and even if you didn't there's no big harm other than bad odors can come out of it. It's already broken so you don't need to worry about breaking the plug - you just don't want to damage the threads the plug goes into.
#2 requires prompt attention and needs to be augered out (through the outside cleanout after you get the plug out). A place like Ace Hardware or some tool rental yard will often rent out big powered drain augers that you can use. These can be tricky to use and you can even hurt yourself on them so don't do it unless you are sure you can handle it safely. Seems like I saw a rental for around $50. Or you can call a plumber. Prices can vary significantly so talk money on the phone so you aren't surprised by the bill.
06-15-2010, 11:47 PM
#14
Ok. I think, now I should call a plumber. What should I be telling him on the phone to make sure he understands what I am talking about.
07-05-2010, 12:24 PM
#15
Final update: Also sorry for the late update:
I called Drain Cleaning company and they cleaned it in a few minutes.
Put a cap to the clean-out access. Job is done for $50. I am happy..
Thank you for all your suggesstions and help!! Appreciated.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
