Old 10-26-2011, 11:58 AM   #1
Not sure water heater
Well, I read thru some posts on water heaters and the answer I am looking for just isn't in any or well what I read they weren't. I could be wrong!
Anyways- I have replaced the upper and lower elements and thermostats. And still only getting luke warm water! Any ideas. Electrical work I am a total blonde too. upper Element is reading correct. And of course lower doesn't read unless upper is at full. Checked Temp and it's set at highest on both. When I switched out I marked all the wires so I knew where they went. Now what should I look at or be looking for? Would a picture work incase the wiring was messed up anyways? I am at ends with this! Would love to take a hot shower! LOL
Csmomma is offline   Reply With Quote
Old 10-26-2011, 12:03 PM   #2
the Musigician
DangerMouse's Avatar
HI and welcome to the forum.
Sounds to ME like only one is still working. Did you open a (hot) faucet while you filled the tank?
BEFORE turning it on?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 10-26-2011, 12:08 PM   #3
Yep I burped the system before turning it on!
Old 10-26-2011, 12:14 PM   #4
the Musigician
How long did it take to fill? How many gallons?
Have you checked your panel for a popped breaker?
DM
Old 10-26-2011, 12:19 PM   #5
Ok (taking deep breath) it is a whirlpool 50 gal. Took very little time to fill. Was filled yesterday around 6pm. Checked breakers and we good to go there.. I had it re wired (from breaker to tank) and new breaker put in about a month ago! Will kicking it make it work?! Because I think it would make me feel better.
Old 10-26-2011, 12:21 PM   #6
Are you as puzzled as I am?!
Old 10-26-2011, 12:23 PM   #7
the Musigician
As in.....? A couple of minutes?
DM
Old 10-26-2011, 12:25 PM   #8
honestly i wasn't timing it so I will take a approximate guess here. About 20 minutes or so! I know that's no help I am sorry for that part!
Old 10-26-2011, 12:25 PM   #9
the Musigician
Oh, and feel free to kick it if you wish, it'd make ME feel better anyway!
DM
Old 10-26-2011, 12:26 PM   #10
the Musigician
....and you had it turned off at the breaker until it had FINISHED filling, right?
DM
Old 10-26-2011, 12:33 PM   #11
Yes, I had it turned off at the breaker until completely filled and made sure it was burped and I pushed the reset button also.. Oh, if it was hidden camera day I'd win millions for cursing and kicking the dang water heater! lol Bad part is I think it's winning this fight!
Old 10-26-2011, 12:40 PM   #12
the Musigician
You kicked it? Well there you go then, you BROKE it.
Seriously though, this is an unusual one. It still seems one element is not working, or a thermostat is toasted or something. If the top element is ok, then you'd have hot water for a very short time, right guys?
Chime in any old time you guys......
DM
Old 10-26-2011, 12:46 PM   #13
Yea Chime in people! This mom is getting really sick of heating up water to give kids baths! LOL So, ok so is there the possibility that I could have bought a crapped out thermostat and/or element? I did take pictures of the wiring! Could a wire be bad? they look fine by the outside! Um, what other nonsense question could I ask! hmmmm Oh yea if I broke it by kickin it how do we fix it then? HA HA HA
Old 10-26-2011, 12:51 PM   #14
the Musigician
The water heater or your toe?
If it were me, I'd start over. Cut the power, drain the tank, pull the elements, test for continuity, go from there. Of course, I could be way off base too, but since all the plumbing guys are sleeping today.....
DM
Old 10-26-2011, 01:19 PM   #15
As DM said, turn the power off, and check the elements for continuity, but you do not need to drain the heater or remove the elements to do so; again, POWER OFF, remove the wires on the individual elements, and check across those terminals.
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 10:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 01:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
