Not Leaking-just Not Working - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-03-2008, 09:18 AM   #1
Unhappy
Not leaking-just not working
All of the faucets in the house work except for this one in the master bath. The hot water is not coming out of the faucet. I have cold water but when I turn the faucet to the hot it stops flowing. Now it is starting to do this in my shower (serperate). Can anyone help? Thanks.
nopro_needhelp is offline   Reply With Quote
Old 11-03-2008, 10:45 AM   #2
Just guessing that the faucet is a single handle model. Usually, this happens due to a bad cartridge. May be a bad "O" ring or broken spring. You will need to remove the cartridge to check it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-03-2008, 10:59 AM   #3
Thanks I will try this and see what happens.
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
Ice and Water Shiled over or under Drip Edge? Leaking Roof sbt3 Roofing/Siding 8 05-02-2008 11:00 PM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
