Old 07-12-2010, 11:39 AM   #1
Not enough mortar under bathtub
We had a new acrylic/fibreglass tub installed with a mortar base but it still feels spongy along sides and part of the middle. I looked underneath and the mortar is only covering the back bottom and a maybe a 6 inch spread in the middle. Is it going to crack eventually? Can this be fixed to be more stable?
Kimma is offline   Reply With Quote
Old 07-12-2010, 06:40 PM   #2
If there is movement in the bottom there is a risk of it cracking. Who knows though, it may well last many years. I have heard of using espandable foam insulation under tubs but you need to be careful not to use too much and cause over expansion.
Jim F is offline   Reply With Quote
Mortor bed under bathtub: what about 15 years from now when ripping out tub? lazzlazz Kitchen & Bath Remodeling 6 05-20-2010 09:56 PM
Plan to install new fiberglass tub; questions about process for mortar underneath lazzlazz Kitchen & Bath Remodeling 1 05-02-2010 05:53 PM
Basement Concrete Block Mortar Seepage Advice Nightcrawler Building & Construction 6 09-22-2009 09:57 PM
installing new bathtub, secure using construction adhesive or mortar? bsd Plumbing 24 03-05-2009 02:47 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
