Not Enough Hot Water In The Shower... - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-14-2010, 03:29 PM   #16
They're all fixer-uppers
J187's Avatar
Rewards Points: 516
Originally Posted by oh'mike View Post
What kind of breaker have you got? sounds like both 110 lines are coming off the same leg---
Start working your way back to the source(all the way to your main breaker---)
very strange-- ?
Well, no, because the power is 220 at the junction box and at the top two terminals of the thermostat....
Here is a BIZZARE twist.
So I started trying to figure out what would put the two legs back in phase with each other when it reaches the element. I tested the thermostat for continuity between the left side and right side bottom terminals and found a positive result - also, there is no continuity between the left bottom terminal and the left top...
I have the old thermostat that I took out before.. I test that for continuity and got the exact opposite result
Now, I tested both stats without any wires... is it possible that the new one is just simply wired backwards internally from the factory? Thereby switching the two 110 legs back into phase with each other? I am going to the hardware store to buy a new stat and test that.
J187 is offline   Reply With Quote
Old 02-14-2010, 06:04 PM   #17
DIY staff
Rewards Points: 7,174
Boy I sure wish a Sparky would step in---Where is NAP and Scuba Dave ?????
Old 02-14-2010, 07:38 PM   #18
J187's Avatar
Rewards Points: 516
So I bought a new stat. It tests exactly opposite as the one I took out. Once installed, 220 at the elements, strange huh? Let's see if it holds up to showers now.
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 12:17 PM
Water from Shower Will Not Cool GuyG Plumbing 1 08-09-2009 02:18 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 10:24 AM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 05:27 AM
