Northern Camp - On Demand Water Conversion Help?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-16-2011, 09:31 PM   #1
Northern Camp - On Demand water conversion help??
Hi all - I have a small camp in Northern Maine. Currently all plumbing is below the camp in a dirt floor/uninsulated crawl space. Current plumbing is 3/4 pvc?? feeding a hot water tank, 2 sinks, a toilet and a shower. Heat is LP Rinnai and wood stove. all appliances are within 10' of each other.
My plan is to bring my pump up into the main building, re-run all feed lines and keep all drain lines as connected below and insulate the floor. There is a utility room directly in the middle of all appliances that will easily allow for new pex or pvc lines. I wish to replace the water tank with an on demand water heater.
Since this is a part time use camp with questionable insulation, I drain all pipes whenever I leave. I'm hoping you guys can assist me in determining the most adequate water heater for my needs. Since I already have lp, should I go that route? What about electric? (effeciency is not a major concern)? What about a unit that can be drained easily? Just don't want to make a mistake.
Thanks in advance for the help.
zachalyse is offline   Reply With Quote
Gas Valve 7200 IPER-S7C LP Conversion mikefrommi HVAC 5 03-06-2011 09:40 PM
Weather sealing/insulating camp dirt crawlspace? zachalyse Building & Construction 3 11-09-2010 07:00 PM
Garage Conversion SDEngr Remodeling 13 06-01-2010 04:11 PM
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 03:57 PM
Deck at seasonal camp site... Spike99 Project Showcase 0 12-24-2007 03:09 PM
