Is This Normal For Shower? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 09:37 AM   #1
Is this normal for shower?
Hi all
I am new here, not sure i am posted in the right place...if not please move to the appropriate section of the forum.
I try to find out what causing leaking from upstairs. Last years i thought it the shower and i hired someone to re-done the title and now still leaking different spot. I opened the the drain this morning and i still see the water from the pipe..is this normal? i was about to called a plumber to put the snake down but i am not sure.
sorry for newbie question..i am not a handy man..i am a computer guy
Thanks,
bartsimpson is offline   Reply With Quote
Old 02-19-2012, 09:40 AM   #2
Experienced
Jackofall1's Avatar
Yes water in the pipe is normal, it is a "Trap", if it was dry you would be smelling sewer gas.
As for the leaking, have you identified the location or are you looking at the wet spot on the ceiling.
Mark
Old 02-19-2012, 09:53 AM   #3
Thanks for fast replied Mark;
Look like the leaking from the shower and i just put caulk around the corner this morning. The tile is from last year so i think that not a problem.. The only problem i can think of is leaking pipe around the shower.
I was thinking to hired a drywall guy to cut the ceiling to see what is the problem..is this a good ideal?
Thanks,
Tom
Old 02-19-2012, 09:55 AM   #4
Experienced
Jackofall1's Avatar
Thanks,
Tom
Absolutely a good idea, if fact cutting drywall is easily done, you need to determine where the leak is before (if not too late already) there is structure damage from rot.
Not all tile installers are created equally and if not done correctly tiled shower enclosures are a big problem, they need a liner under the tile as tile and grout is not water proof.
Mark
Sliding Glass door Issue - Where to find a slightly smaller than 'normal' door LordX Building & Construction 1 01-18-2012 01:49 PM
Is This Normal? (frost in new fridge) Old Lady Appliances 23 08-16-2011 09:59 AM
Overflow drain stained black, normal? Drywallhelp Plumbing 5 08-14-2011 07:48 PM
coolant indicater staying cooler than normal raptor99 Automotive Repairs 5 02-16-2010 03:19 AM
damage to prefinished floors normal during a remodel? zzman Remodeling 15 12-04-2008 05:25 PM
