Is This Normal On Pressure Relief Valve Test - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2011, 02:47 PM   #1
is this normal on pressure relief valve test
Hi,
I tested my pressure relief valve today as it has been a year and when I pushed up the silver tab to see if water comes out, water actually was dripping from the silver tab when it was pushed up all the way. If I lift it a little, nothing leaks. Let me note that the actual drainage works just fine, but it is just a small leak when letting all the water come out. I attached a picture to better explain myself. I am just not sure if this is normal or not as it is my first house
http://i.imgur.com/kzkLw.jpg
Thanks in advance.
thesaintjim is offline   Reply With Quote
Old 11-20-2011, 03:11 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Sounds like you need a hobby!
Everything is fine with the water heater.
Old 11-20-2011, 03:18 PM   #3
haha, thanks for the reply
Old 11-20-2011, 03:27 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I gotta tell ya Jim...
In all my years I don't think I have ever heard of anyone "testing" their pressure relief valve on their water heater. I'm not saying it's a bad thing, it's just something that no one ever does as far as I know. I have to admit I have pulled on a few of those things myself over the years but it wasn't to test anything, it was purely for my entertainment. In some cases it is a risky thing to do and I wouldn't suggest anyone do it.
I'm curious to know what it is you expected to find in your test. What most people would find would be scalding hot water blasting at them at the rate of maybe sixty psi. That's a dangerous thing to participate in.
Old 11-20-2011, 03:33 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 348
I bet you read somewhere to test the T&P annually or something like that, but I advise against testing those things. They end up dripping.
Old 11-20-2011, 03:38 PM   #6
Was just following my manuals maintenance schedule. Drain tank and make sure the relief valve emptys into the hose as normal
Old 11-20-2011, 03:43 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good Lord!!!
Is that what the manufacturer tells you to do? They are inviting litigation.
Oh well, at least you have the T&P insulated, that's a good thing. First for me, but good thing for you.
pressure relief valve leaks f9 flier Plumbing 21 06-14-2011 07:55 PM
Irrigation valve low pressure tatums4 Landscaping & Lawn Care 13 06-12-2011 07:16 PM
Leaking Pressure Relief Valve of Boiler rob07030 Plumbing 2 11-02-2010 08:11 AM
Water Heater Pressure Relief Valve Leaking. merton Plumbing 2 03-29-2010 08:37 PM
in line pressure relief valve hidden 1 Plumbing 2 02-22-2009 05:52 PM
