Normal Height For Sink Waste Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2012, 01:17 PM   #1
Rewards Points: 28
Normal height for sink waste pipe?
Is there a rule of thumb for how high off the floor a waste pipe for a kitchen sink should be where it comes out of the wall?
I'm remodeling my kitchen and will be moving the sink from a corner to against a wall. Also the same question for the water supply lines.
Thanks,
Rut
rutledj is offline   Reply With Quote
Old 10-15-2012, 01:25 PM   #2
16 inches above finished floor. if you plan on a real deep sink go 15 inches.
Old 10-15-2012, 01:30 PM   #3
Rewards Points: 14,300
http://www.informationdestination.ce...Dimensions.pdf
Old 10-15-2012, 01:34 PM   #4
Rewards Points: 28
Thanks! Very helpful.
Installing toilet above horizontal above ground waste pipe alexlacelle Plumbing 6 02-28-2012 09:01 PM
How to clean a PVC waste pipe from rubber washer remains? sukhenkoi Kitchen & Bath Remodeling 3 03-04-2011 10:10 PM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 12:07 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 01:36 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
