Normal? Clogged Toilet Connected To Shower & Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2012, 09:57 AM   #1
Question
Normal? Clogged Toilet connected to Shower & Sink
Last night my toilet would not flush fully. I believe it is my fault since I have been using medicated wipes very often (I now throw them in the garbage).
After the first 2 attempts to flush I gave up and took my shower. When I got out I tried again about 4 times, having to hold down the lever, the water filled up and then only slightly went down. I plunged and there was not much action, but I noticed when I plunged I could hear the water bubbling from the shower drain. I could even see the water from the shower drain moving!
I gave up again, washed my hands and when the water ran from the sink the toilet water bubbled! This is very strange as I thought they should not be connected.
Looking for a solution to unclog, is Drano ok? Should I be concerned and have a plumber come or does this sound normal?
Thanky ou for your time
KaarenStyles is offline   Reply With Quote
Old 09-20-2012, 10:02 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Drain-o is not ok, and it wont do anything to clear wipes.
Wipes are NOT ok to put down any drain. They may say flushable, but that's a sales gimmick.
Yes, all of your drains are connected, and it sounds like they're plugged up downstream of your sink and shower, which means when you use one and the line is full of water, the air is pushing itself back out the traps. (bubbles)
I think you need a pro for this one.
Sorry.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
KaarenStyles (09-20-2012)
Old 09-20-2012, 10:10 AM   #3
If I Drano the sink and/or shower instead of the toilet could that help?
Old 09-20-2012, 12:08 PM   #4
Doing it myself
Alan's Avatar
No. As I said, it sounds like the mainline is clogged. Doesn't matter where you put the draino, it's going to end up in the same spot, and I bet it wont break up the wipes.
Not to mention that stuff is really bad on the pipes AND, if you end up having to call a pro anyway, he's going to be really pissed if he has to get draino on his hands. (it's very caustic and it burns the skin, believe me. )
Journeyman Plumber
Old 09-20-2012, 01:03 PM   #5
You can try unclogging it yourself with a snake. Probably best to do that from the toilet, it will be easier to get it through since the pipe is wider there. Just get a 15' or so snake and give it a shot.
If you do call a professional that is what they will do and it will cost you $$$. Buy a snake at HD for $10-$15 and it could save you.
NHtransplant is offline   Reply With Quote
Old 09-20-2012, 06:24 PM   #6
DIY staff
Rewards Points: 7,174
A snake large enough to clear the main line will not go through a toilet.
The toilet must be removed first--or better yet,see if there is a clean out plug---
Old 09-20-2012, 07:56 PM   #7
Rewards Points: 582
sorry this is not a diy project...need electric eel ...danger roy robinison...
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (09-21-2012)
Old 09-20-2012, 08:41 PM   #8
Doing it myself
Alan's Avatar
Don't remove the toilet if the line is still clogged, though.
Journeyman Plumber
Tags
plumbing problem
Basement shower filling with water from upstairs sink. twags Plumbing 4 05-23-2011 03:02 PM
Removing a shower replacing with sink HuskySkull Plumbing 0 01-17-2010 12:08 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Can my corner sink (and toilet) be salvaged?? wombosi Plumbing 3 11-10-2008 10:44 AM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 09:05 AM
