Nonstop Flushing - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2012, 11:54 PM   #1
Rewards Points: 101
Nonstop Flushing
One of the urinals in my restaurant's bathroom keeps flushing. I assume the valve must be stuck open. I've fixed tank toilets that continue to run (replacing the flap), but this doesn't have that.
Dare I attempt or should I call a plumber?
michaelson is offline   Reply With Quote
Old 11-27-2012, 12:00 AM   #2
Rewards Points: 13,260
See that flat head screw in the center of the fitting where it turns to go into the top of the urinal? Turn it in to shut off the water flow.
Since you did not include the make or model number here's some ideas where to find the parts list.
http://www.bing.com/images/search?q=...ures&FORM=IGRE
Old 11-27-2012, 12:06 AM   #3
Rewards Points: 101
It's a Zurn Aquaflush value; I think the model number is Z6003PL-WS1
Old 11-27-2012, 12:31 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 442
Turn the screw Joe references clockwise to turn off the water.
Now try to flush it a couple times to relieve the pressure. Now you can attempt to remove the top dome on the flush valve. They can be very stubborn. Once inside, you can pull the diaphragm and rinse it really well to remove any debris. Also, slowly turn on the water to allow it to overflow out of the body- this will help flush more debris out. Reassemble and try it. If you don't feel confident doing these steps or it doesn't cure it, or you can't get it apart, then yes, call a plumber
Old 11-27-2012, 08:14 AM   #5
Non stop flushing
First off, you must turn off your water when working on any type of flush valve. The relief valve may not be seating properly or the bypass orifice is clogged of foreign material. There also may be an invisible gelatinous film from over-treated water. Usually a flush valve repair kit for the specific model will alleviate the problem
jnc401 is offline   Reply With Quote
Old 11-27-2012, 09:36 AM   #6
Rewards Points: 101
I got the valve apart, cleaned it out, and got it back together without leftover parts. That didn't fix the problem; after the first flush it continued running.
Should a new diaphragm fix it?
Old 11-27-2012, 09:40 AM   #7
Plumber
Rewards Points: 442
yes it should
Old 11-27-2012, 09:40 AM   #8
It should, did you see any other parts thet look messed up?
Old 11-27-2012, 03:53 PM   #9
Rewards Points: 101
Nothing looks messed up... The cleaning didn't fix it and it didn't look dirty to begin with. I picked up a repair kit at a janitor supply store I use. After dinner I will put it in.
Old 11-27-2012, 10:29 PM   #10
Rewards Points: 101
I got it fixed with the repair kit!
Old 11-27-2012, 11:20 PM   #11
Plumber
Rewards Points: 442
Feels good huh!
Toilet flushing issue grand_canyon Plumbing 5 11-28-2011 12:27 PM
Toilet not flushing away contents effectively.... conbutts Plumbing 6 05-24-2011 11:27 AM
Toilet backfill after flushing hohadcr Plumbing 6 12-20-2009 05:01 PM
slow flushing toilet annoyances mcvane Plumbing 12 11-13-2008 04:00 PM
Loud pssst noise when flushing mcvane Plumbing 3 08-22-2007 09:11 PM
